Technical Data 4372
Effective January 2018
Supersedes September 2017
DRAQ127
Automotive grade
Dual winding, high power density shielded drum core
power inductors
Applications
Product features
AEC-Q200 qualified
Dual winding inductors that can be used
as a single inductor, SEPIC, Flyback, or
other coupled inductor/transformer
applications (1:1 turns ratio)
Windings can be connected in series or
parallel, offering a wide range of
inductance and current ratings
200 Vac isolation between windings
12.5 mm x 12.5 mm x 8.0 mm surface
mount package
Mechanical secure mounting for high
shock and vibration environments
Ferrite core material
Moisture Sensitivity Level (MSL): 1
Body electronics
o Headlamps, tail lamps and interior
lighting
o Heating Ventilation and Air Conditioning
controllers (HVAC)
o Doors, window lift and seat control
Advanced driver assistance systems
o Adaptive cruise control (ACC)
o Collision avoidance system
o Car black box system
Infotainment and cluster electronics
o Audio subsystem: head unit and trunk
amp
o Digital instrument cluster
o In-Vehicle Infotainment (IVI) and
navigation
Chassis and safety electronics
o Electronic Stability Control system (ESC)
o Electric parking brake
o Electronic Power Steering (EPS)
Engine and powertrain systems
o Diesel/gasoline engine management
o Powertrain Control Module (PCM)/
Engine Control Unit (ECU)
o Transmission Control Unit (TCU)
Environmental Data
Storage temperature range (Component):
-40 °C to +165 °C
Operating temperature range: -40 °C to +165 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
Technical Data 4372
DRAQ127
Automotive grade
Dual winding, high power density shielded drum core power inductors
Product specifications
Parallel Ratings
OCL1
±25%
(μH)
Part Number
6
Irms2
Isat13
Isat24
(A)
(A)
(A)
Series Ratings
DCR (Ω) DCR (Ω)
@ +20 °C @ +20 °C
(Typ.)
(Max.)
K-Factor5
OCL1
±25%
(μH)
Irms
Isat13
Isat24
(A)
(A)
(A)
2
DCR (Ω) DCR (Ω)
@ +20 °C @ +20 °C
(Typ.)
(Max.)
DRAQ127-100-R
9.63
6.02
11.2
8.96
0.018
0.022
24.0
38.5
3.01
5.60
4.48
0.072
0.089
12.0
DRAQ127-150-R
14.9
4.83
9.03
7.23
0.027
0.032
19.4
59.6
2.41
4.52
3.61
0.108
0.128
9.70
DRAQ127-220-R
22.0
3.98
7.57
6.05
0.040
0.047
16.2
88.0
1.99
3.79
3.03
0.162
0.192
8.10
DRAQ127-330-R
32.0
3.22
6.22
4.98
0.060
0.072
13.3
128.0
1.61
3.11
2.49
0.240
0.288
6.65
DRAQ127-470-R
47.9
2.62
5.09
4.07
0.091
0.110
10.9
192.0
1.31
2.54
2.03
0.364
0.440
5.45
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0
Adc
2. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +165 °C under worst case operating conditions verified in the end
application.
3. Isat1: Peak current for approximately 30% rolloff at +25 °C.
4. Isat2: Peak current for approximately 40% rolloff at +125 °C.
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I.
Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in µH), ∆I (Peak-to-peak
ripple current in Amps).
6. Part Number Definition: DRAQxxx-xxx-R
- DRAQxxx = Product code and size
- xxx= Inductance value in uH, R = decimal point, If no R is present then 3rd
digit equals number of zeros.
- “-R” suffix = RoHS compliant
Dimensions - mm
Top view
Recommended pad layout
Front view
Schematic
Bottom view
1
2
L1
1
L2
L1
4
3
D ual Inductor
2
1
4
3
L2
3
www.eaton.com/electronics
2
L1
S eries M ode
Part Marking: DRAQ127, ### = inductance value in µH, R = decimal point; if no R is present, then 3rd digit equals number of zeros wwllyy = Date code,
R = revision level
All soldering surfaces to be coplanar within 0.10 millimeters
Tolerances are ± 0.2 millimeters unless stated otherwise.
Do not route traces or vias underneath the inductor
*Special Characteristic epoxy protrusion or any flashing from the plastic on the header/base can be below the terminal surface and must not exceed 0.08
mm beyond the bottom surface of the terminal.
2
K-Factor5
L2
4
P arallel M ode
DRAQ127
Automotive grade
Technical Data 4372
Packaging information - mm
DRAQ127
-xxx
wwllyy R
Supplied in tape and reel packaging, 350 parts per 13” diameter reel.
Temperature rise vs. total loss
80
70
Temp. Rise(°C)
60
50
40
30
0 .2
0 .3
0 .4
0 .5
0 .6
0 .7
0 .8
0 .9
1
1 .1
1 .2
1 .3
1 .4
1 .5
Total Loss (W)
3
Technical Data 4372
DRAQ127
Automotive grade
Core loss vs. Bp-p
500kHz
1MHz
10
300kHz
200kHz
100kHz
Core Loss (W)
1
0 .1
0 .0 1
10 0
10 0 0
10 ,0 0 0
Bp-p (Gauss)
Inductance characteristics
% of OCL vs. % of Isat1
120%
110%
100%
90%
% of OCL
80%
70%
-4 0°C
60%
50%
+2 5°C
40%
30%
+8 5°C
20%
+1 2 5°C
10%
0%
0%
10%
20%
30%
40%
50%
60%
70%
% of Isat1
4
80%
90%
100%
110%
120%
130%
140%
DRAQ127
Automotive grade
Technical Data 4372
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“DRAQ127-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 350+6.49691350+0.84213
- 700+6.12619700+0.79407
- 1050+5.919331050+0.76726
- 1750+5.668981750+0.73481
- 2450+5.509982450+0.71420
- 3500+5.346463500+0.69301
