DRAQ127-330-R
DRAQ127-330-R
    EATON(伊顿)
    32UH ±25% 4.98A
DRAQ127-330-R 数据手册
Technical Data 4372 Effective January 2018 Supersedes September 2017 DRAQ127 Automotive grade Dual winding, high power density shielded drum core power inductors Applications • • • Product features • • • • • • • • AEC-Q200 qualified Dual winding inductors that can be used as a single inductor, SEPIC, Flyback, or other coupled inductor/transformer applications (1:1 turns ratio) Windings can be connected in series or parallel, offering a wide range of inductance and current ratings 200 Vac isolation between windings 12.5 mm x 12.5 mm x 8.0 mm surface mount package Mechanical secure mounting for high shock and vibration environments Ferrite core material Moisture Sensitivity Level (MSL): 1 • • Body electronics o Headlamps, tail lamps and interior lighting o Heating Ventilation and Air Conditioning controllers (HVAC) o Doors, window lift and seat control Advanced driver assistance systems o Adaptive cruise control (ACC) o Collision avoidance system o Car black box system Infotainment and cluster electronics o Audio subsystem: head unit and trunk amp o Digital instrument cluster o In-Vehicle Infotainment (IVI) and navigation Chassis and safety electronics o Electronic Stability Control system (ESC) o Electric parking brake o Electronic Power Steering (EPS) Engine and powertrain systems o Diesel/gasoline engine management o Powertrain Control Module (PCM)/ Engine Control Unit (ECU) o Transmission Control Unit (TCU) Environmental Data • Storage temperature range (Component): -40 °C to +165 °C • Operating temperature range: -40 °C to +165 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE Technical Data 4372 DRAQ127 Automotive grade Dual winding, high power density shielded drum core power inductors Effective January 2018 Product specifications Parallel Ratings OCL1 ±25% (μH) Part Number 6 Irms2 Isat13 Isat24 (A) (A) (A) Series Ratings DCR (Ω) DCR (Ω) @ +20 °C @ +20 °C (Typ.) (Max.) K-Factor5 OCL1 ±25% (μH) Irms Isat13 Isat24 (A) (A) (A) 2 DCR (Ω) DCR (Ω) @ +20 °C @ +20 °C (Typ.) (Max.) DRAQ127-100-R 9.63 6.02 11.2 8.96 0.018 0.022 24.0 38.5 3.01 5.60 4.48 0.072 0.089 12.0 DRAQ127-150-R 14.9 4.83 9.03 7.23 0.027 0.032 19.4 59.6 2.41 4.52 3.61 0.108 0.128 9.70 DRAQ127-220-R 22.0 3.98 7.57 6.05 0.040 0.047 16.2 88.0 1.99 3.79 3.03 0.162 0.192 8.10 DRAQ127-330-R 32.0 3.22 6.22 4.98 0.060 0.072 13.3 128.0 1.61 3.11 2.49 0.240 0.288 6.65 DRAQ127-470-R 47.9 2.62 5.09 4.07 0.091 0.110 10.9 192.0 1.31 2.54 2.03 0.364 0.440 5.45 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +165 °C under worst case operating conditions verified in the end application. 3. Isat1: Peak current for approximately 30% rolloff at +25 °C. 4. Isat2: Peak current for approximately 40% rolloff at +125 °C. 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I. Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in µH), ∆I (Peak-to-peak ripple current in Amps). 6. Part Number Definition: DRAQxxx-xxx-R - DRAQxxx = Product code and size - xxx= Inductance value in uH, R = decimal point, If no R is present then 3rd digit equals number of zeros. - “-R” suffix = RoHS compliant Dimensions - mm Top view Recommended pad layout Front view Schematic Bottom view 1 2 L1 1 L2 L1 4 3 D ual Inductor 2 1 4 3 L2 3 www.eaton.com/electronics 2 L1 S eries M ode Part Marking: DRAQ127, ### = inductance value in µH, R = decimal point; if no R is present, then 3rd digit equals number of zeros wwllyy = Date code, R = revision level All soldering surfaces to be coplanar within 0.10 millimeters Tolerances are ± 0.2 millimeters unless stated otherwise. Do not route traces or vias underneath the inductor *Special Characteristic epoxy protrusion or any flashing from the plastic on the header/base can be below the terminal surface and must not exceed 0.08 mm beyond the bottom surface of the terminal. 2 K-Factor5 L2 4 P arallel M ode DRAQ127 Automotive grade Dual winding, high power density shielded drum core power inductors Technical Data 4372 Effective January 2018 Packaging information - mm DRAQ127 -xxx wwllyy R Supplied in tape and reel packaging, 350 parts per 13” diameter reel. Temperature rise vs. total loss 80 70 Temp. Rise(°C) 60 50 40 30 20 10 0 0 0 .1 0 .2 0 .3 0 .4 0 .5 0 .6 0 .7 0 .8 0 .9 1 1 .1 1 .2 1 .3 1 .4 1 .5 Total Loss (W) www.eaton.com/electronics 3 Technical Data 4372 DRAQ127 Automotive grade Dual winding, high power density shielded drum core power inductors Effective January 2018 Core loss vs. Bp-p 500kHz 1MHz 10 300kHz 200kHz 100kHz Core Loss (W) 1 0 .1 0 .0 1 10 0 10 0 0 10 ,0 0 0 Bp-p (Gauss) Inductance characteristics % of OCL vs. % of Isat1 120% 110% 100% 90% % of OCL 80% 70% -4 0°C 60% 50% +2 5°C 40% 30% +8 5°C 20% +1 2 5°C 10% 0% 0% 10% 20% 30% 40% 50% 60% 70% % of Isat1 4 www.eaton.com/electronics 80% 90% 100% 110% 120% 130% 140% DRAQ127 Automotive grade Dual winding, high power density shielded drum core power inductors Technical Data 4372 Effective January 2018 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
DRAQ127-330-R 价格&库存
很抱歉,暂时无法提供与“DRAQ127-330-R”相匹配的价格&库存,您可以联系我们找货
DRAQ127-330-R
    库存:1400
    DRAQ127-330-R
    • 350+9.90253
    • 15050+7.31506
    库存:45570
    DRAQ127-330-R
    • 1+10.159701+1.31579
    • 10+9.2580410+1.19901
    • 25+8.8943925+1.15192
    • 50+8.6294450+1.11760
    • 100+8.37070100+1.08409
    库存:672
    DRAQ127-330-R
    • 350+7.84374350+1.01585
    • 700+7.60408700+0.98481
    • 1050+7.466731050+0.96702
    • 1750+7.296471750+0.94497
    • 2450+7.186112450+0.93068
    • 3500+7.070613500+0.91572
    库存:672
