900-00008
900-00008
    PARALLAXINC.
    直流电机 齿轮电机 编码器 6VDC
900-00008 数据手册
Web Site: www.parallax.com Forums: forums.parallax.com Sales: sales@parallax.com Technical: support@parallax.com Office: (916) 624-8333 Fax: (916) 624-8003 Sales: (888) 512-1024 Tech Support: (888) 997-8267 Parallax Continuous Rotation Servo (#900-00008) The Parallax Standard Servo is ideal for adding bidirectional continuous rotation to your robotics projects. Features        Bidirectional continuous rotation 0 to 50 RPM, with a linear response to PWM for easy ramping Accepts four mounting screws Easy to interface with any Parallax microcontroller or PWM-capable device Very easy to control with the PULSOUT command in PBASIC or SX/B Weighs only 1.50 oz (42.5 g) 38 oz-in torque @ 6 V Key Specifications     Power requirements: 4 to 6 VDC; Maximum current draw 140 +/- 50 mA at 6 VDC when operating in no load conditions, 15 mA when in static state Communication: pulse-width modulation Dimensions: approx 2.2 x 0.8 x 1.6 in (5.58x 1.9 x 4.06 cm) excluding servo horn Operating temperature range: 14 to 122 °F (-10 to +50 °C) Quick-Start Circuit Vµ Vservo Vdd White I/O Red Black Vss Microcontroller Continuous Rotation Servo GND Vµ = microcontroller voltage supply Vservo = 4 to 6 VDC, regulated or battery I/O = PWM TTL or CMOS output signal, 3.3 to 5 V; < Vservo + 0.2 V Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 1 of 8 Device Information The Parallax continuous rotation servo relies on pulse width modulation to control the rotation speed and direction of the serv o shaft. Before u sing the servo in a project, it is important to c alibrate the center position of the servo in order to defi ne the pul se width value at which the servo holds still (see the section Calibration – "Center" the Servo on page 4). Specifications Pin Name Description Minimum Typical Maximum Units 1 (White) 2 (Red) 3 (Black) Signal Vservo Vss Input; TTL or CMOS Power Supply Ground 3.3 4.0 5.0 5.0 0 Vservo + 0.2 6.0* V V V *See Board of Education Servo Header Connection Diagram. Power Precautions    Do not use this servo with an unregulated wall-mount supply. Such powe supplies may deliver variable voltage far above the stated voltage. Do not power this servo through the BASIC Stamp® Module's Vin pin, this can deliver voltages above the stated voltage. See the Board of Education Connection Diagram below for jumper settings. Servo current draw can spike while under peak load; be sure your application's regulator is prepared to supply adequate current for all servos used in combination. Board of Education Servo Header Connection Diagram When connecting the servo to the Board of Education ® servo header, be sure the jumper is set t o Vdd (regulated 5 VDC for this board) as shown in the figure below. Failure to place the jumper at this setting can cause damage your servo! (Note: see the Board of Education product documentation for instructions regarding earlier board revisions that do not have a servo header with a jumper.) 15 14 Vdd 13 12 Red Black X4 X5 Vin Using a Separate Power Supply on a HomeWork Board The BASIC Stamp HomeWork Board uses a 9 V battery for a power supply. A servo can drain a fresh 9 V battery in un der 20 minutes! Foll ow these direc tions to build two servo p orts on the breadboard, and power them with a separate battery pack. Hardware Required (1) (1) (2) (2) (4) (4) BASIC Stamp HomeWork Board (serial #555-28158 or USB #555-28188) Battery pack with tinned leads (Parallax #753-00001) Parallax continuous rotation servos 3-pin male-male headers (Parallax #451-00303) Jumper wires (10-pack: Parallax #800-00016 1.5 V AA batteries Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 2 of 8 √ √ √ √ √ Disconnect the 9 V battery from the board, and do not put the AA batteries in their holder yet. Build the servo ports shown by the schematic and wiring diagram below. Double-check to mak e sure the black wire with th e white stripe is conn ected to Vbp , the solid black wire is connected to Vss, and that all the connections for P13, Vbp, Vss, Vbp (another one), and P12 all exactly match the wiring diagram. Connect the servo plugs to the male headers on the right side of the wiring diagram. Connect the 9 V battery, and insert the AA batteries into their holder. Vbp Vbp stands for Voltage battery pack. White Red Black P13 It refers to the 6 VDC supplied by the four 1.5 V batteries. This is brought directly to the breadboard to power the servos for Boe-Bots built with the HomeWork Board. Your BASIC Stam p is still powered by the 9 V battery. Vss Vbp White Red Black P12 Vss Battery pack solid black wire = ground Battery pack black wire with white stripe = Vbp (916) 624-8333 www.parallaxinc.com www.stampsinclass.com Vdd Vin (916) 624-8333 www.parallaxinc.com www.stampsinclass.com Rev B Vdd Vss Vin Rev B Vss X3 X3 P15 P14 P13 P12 P11 P10 P9 P8      Port connections P13 Vbp Vss Vbp P12 P15 P14 P13 P12 P11 P10 P9 P8      White Red Black Red White Servo connections by wire color HomeWork Board with servo ports built on the breadboard, with a separate battery pack power supply for the servos. Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 3 of 8 Calibration – "Center" the Servo The servo has a pot entiometer access port, right above the plac e where the cable attaches to the c ase. The port allows the user to adjust the servo to hold completely still when receiving a 1.5 ms pulse width. This is the value in the "center" of the range of control pulses the servo will accept. To center the servo, program your host device to deliver a 1.5 ms pulse, continually refreshed ever y 20 ms. S ample calibration code is giv en below f or all BASIC Stamp model s, Spin for the Propeller ™ P8X32A microcontroller, and SX/B for the SX chip. All are avail able for downl oad from th e 900-00008 product page at www.parallax.com. Connect the servo to your microcontroller's I/O pin. The example programs below specify an I/O pin. BASIC Stamp Calibration Code - for all BS2 models √ √ Connect the servo to BASIC Stamp 1/O pin P12, or update the ToServo PIN declaration. Run the program, and gently twist the potentiometer adjustment screw until the servo does not turn or vibrate. NOTE: Calibrating the servo may take some patience. The potentiometer is very sensitive so a very light touch will be required. ' CenterParallaxCrServo.bs2 ' {$STAMP BS2} ' {$PBASIC 2.5} #SELECT $Stamp #CASE BS2, BS2E, BS2PE Center CON 750 #CASE BS2SX, BS2P, BS2PX Center CON 1875 #ENDSELECT ' PULSOUT Duration units are 2 us for these models ' PULSOUT Duration units are 0.8 us for these models ToServo PIN 12 ' connect servo to I/O pin P12, or change it here DO PULSOUT ToServo, Center PAUSE 20 LOOP ' ToServo pin outputs 1.5 ms pulse ' refresh pulse every 20 milliseconds Propeller Chip Calibration Code – for P8X32A √ √ √ Download and unzip the Propeller code file from the 900-00008 product page. Connect the servo signal pin to Propeller I/O pin P0. Run the program CenterParallaxServo.spin, and gently twist the potentiometer adjustment screw until the servo does not turn or vibrate. NOTE: Calibrating the servo m ay take some p atience. The potentiometer is very sensitive so a very light touch will be required. {{ CenterParallaxServo.spin For centering Parallax Continuous Rotation Servo or holding Parallax Standard Servo at 90° position. Sends a 1.5 ms pulse approx every 20 ms }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 servoPin = 0 ' System clock → 80 MHz ' Using 5 MHz external crystal oscillator ' Servo signal to this I/O pin-change if needed PUB CenterServo | tInc, tc, tHa, t Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 4 of 8 ctra[30..26] := %00100 ctra[8..0] := servoPin ' Configure Counter A to NCO frqa := 1 dira[servoPin]~~ ' Set up cycle and high times tInc := clkfreq/1_000_000 tC := tInc * 21_500 tHa := tInc * 1500 t := cnt ' Mark counter time repeat phsa := -tHa t += tC waitcnt(t) ' ' ' ' Repeat PWM signal Set up the pulse Calculate next cycle repeat Wait for next cycle Communication Protocol The Parallax Continuous Rotation Serv o is controlle d through pulse width modulation. Rotational speed and direction are determi ned by the d uration of a high pulse, i n the 1.3– -1.7 ms range. In order for smooth rotation, the servo needs a 20 ms pause between pulses. Below is a sample timing diagram for a centered servo: As the length of the pulse decreases from 1.5 ms, th e servo will gradually rotate faster in th e clockwise direction, as can be seen in the figure below: Likewise, as the length of the pulse increases from 1.5 ms, the servo will gradually rotate faster in the counter-clockwise direction, as can be seen in the figure below: Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 5 of 8 Voltage and RPM: Maximum RPM will vary with input voltage; 50 RP M @ 5 V is typical. Using regulated Vdd as the sup ply source wi ll reduce fluct uations in RPM for a given pulse width that might otherwise occur with unregulated battery supplies. BASIC Stamp® Programming Examples PBASIC has a PULSO UT command that sets the I/O Pin to an output and sends a pulse of the specified Duration. Since the servo needs this pulse refreshed every 20 ms for continuous operation, the PULSOUT command is put in a coun ted FOR…NEXT loop to su stain continuous operation for the speci fied number of cycles. PULSOUT Pin, Duration Different BASIC Stamp m odules use different units for the P ULSOUT command's Duration argument. When adapting BS2 code to another BASIC Stamp model, you may need to make adjustments. The table below lists the PULSOUT ranges for each BASIC Stamp microcontroller. See the BASIC Stamp Manual or BASIC Stamp Editor Help for more information. BS1 1.3 ms (Full speed clockwise) 130 1.5 ms (Center, no rotation) 150 1.7 ms (Full speed counterclockwise) 170 BS2, BS2e, BS2pe 650 750 850 BS2sx, BS2p, BS2px 1625 1875 2125 BASIC Stamp Model The example shown below for a BASIC Stamp 2 causes a servo connected to BASIC Stamp 1/0 pin 12 to first rotate full-speed counterclockwise for about 3 seconds, hold still f or about 3 seconds, and then rotate counterclockwise for about 3 seconds. ' RotateParallaxCrServo.bs2 ' {$STAMP BS2} ' {$PBASIC 2.5} counter VAR Word servoPin PIN 12 ' change I/O pin for servo signal here FOR counter = 1 TO 100 ' Rotate counterclockwise for ~3 seconds PULSOUT servoPin, 850 PAUSE 20 NEXT Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 6 of 8 FOR counter = 1 TO 100 ' Hold still for ~3 seconds PULSOUT servoPin, 750 PAUSE 20 NEXT FOR counter = 1 TO 100 ' Rotate clockwise for ~3 seconds PULSOUT servoPin, 650 PAUSE 20 NEXT END For more examples with the BASIC Stamp 2, incl uding 2-wheeled robot maneuvers and ramping, see Robotics with the Boe -Bot Chapter 4 , available for free downl oad from the 28132 product page at www.parallax.com. Propeller™ P8X32A Application The program below uses counter modules to rotate the servo first clockwise at full speed for 2 seconds, then rests for 2 seconds, and rotates counterclockwise at full speed for another 2 seconds. This code can also be downloaded from the 900-00008 product page. {{ ServoContinuousRotation.spin Turn Parallax Continuous Rotation Servo clockwise full speed for 21 sec. hold still 2 sec, and then counterclockwise full speed for 2 sec. }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 servoPin = 0 ' System clock → 80 MHz ' Using 5 MHz external crystal oscillator ' Servo signal to this I/O pin-change if needed PUB CenterServo | tInc, tc, tCtr, tCw, tCcw, t ctra[30..26] := %00100 ctra[8..0] := servoPin ' Configure Counter A to NCO frqa := 1 dira[servoPin]~~ tInc tC tCtr tCw tCcw t := := := := := := clkfreq/1_000_000 tInc * 21_500 tInc * 1500 tInc * 1300 tInc * 1700 cnt ' ' ' ' ' ' 1 μs increment Low pulse Center pulse = 1.5 ms Clockwise fast = 1.3 ms Counter-Clockwise fast = 1.7 ms Mark counter time repeat 100 phsa := -tCw t += tC waitcnt(t) ' ' ' ' Repeat PWM signal 100x Set up clockwise fast pulse Calculate next cycle repeat Wait for next cycle (20 ms) repeat 100 phsa := -tCtr t += (tC + 200) ' Repeat PWM signal 100x ' Set up the center pulse ' Calculate next cycle repeat Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 7 of 8 waitcnt(t) repeat 100 phsa := -tCcw t += (tC - 200) waitcnt(t) ' Wait for next cycle (20 ms) ' ' ' ' Repeat PWM signal 100x Set up counter-clockwise fast pulse Calculate next cycle repeat Wait for next cycle (20 ms) Revision History Version 2.1: corrected values in BASIC Stamp Model PULSOUT table; updated example programs to use a constant for the servo pin. Version 2.2: added Voltage and RPM note on p age 6. Added Usin g a Separate Power Supply on a HomeWork Board section beginning on page 2. Updated specifications. Copyright © Parallax Inc. Parallax Continuous Rotation Servo (#900-00008) v2.2 10/24/2011 Page 8 of 8 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Parallax: 900-00008
900-00008 价格&库存
很抱歉,暂时无法提供与“900-00008”相匹配的价格&库存,您可以联系我们找货
  • 1+181.37780
  • 5+175.94178
库存:138
