DCmind Brushless motor
Data sheet
Series
80 140 051
4 x M5 trheaded holes on 40mm diameter, 4,5 mm thread depth
Input - Output cable with Molex connector
80 140 TNI21
Power supply cable
General characteristics
Power supply
Direct current voltage supply
Nominal voltage range
Max. current
Vdc
A
12 -> 32
10
Drive
Type
TNI21
Built-in drive
Internal encoder
12 pulses per turn
Control
12 Vdc
Motor characteristics (1)
24 Vdc
32 Vdc
rpm
A
A
2 900
0,34
0,08
4 000
0,29
0,085
4 000
0,27
0,09
rpm
mNm
W
A
1 900
193
38
5,2
62
4 000
184
77
4,4
74
4 000
178
75
3,2
73
rpm
mNm
W
A
1 600
250
42
6,5
53
3 050
358
114
10
48
4 000
358
150
10
47
rpm
mNm
W
A
930
358
35
10
3 050
358
114
10
4 000
358
150
10
+-10%
At nominal
Speed
Torque (2)
Output power
Current
Efficiency
Security
+-10%
+-10%
At max. output power
Speed
Torque
Output power
Current
Efficiency
Others
Life (3)
Rotor inertia
Thermal Resistance
Thermal time constant
Rotor pole number
Cogging torque
Weight
Noise level
Short-circuit of outputs
Input inverted
Low voltage
Short high voltage
Stop at max internal drive temperature (2)
Drive temperature allowing to restart
h
gcm²
°/W
mn
mNm
kg
dBA
20 000
75
3
11
0,95
40
Vdc
Vdc
°C
°C
< 10
> 36
110
90
N
N
°C
°C
Vdc
class
severity
IP
40
-30 -> +70
-40 -> +80
level
level
level
class
3
3
1
B
Generic parameters
+-10%
At peak torque
Speed
Torque
Output power
Current
4 quadrants - low braking
4 quadrants with regenerative energy
Type" Trapezoidal"
+-10%
Output shaft with ball bearings
Max. Radial force
(12mm from front face)
Max. axial force(4)
Temperature range
CEI60068-2-1/2
Storage temperature
Dielectric
1min 2mA 50Hz
CEI60335
Motor insulation
CEI60085
Salt spray
CEI60068-2-58
Degree of protection
CEI60529
E
48h
65M
(output shaft not included)
EMC
Electrostatic Discharge
Electrical fast transsient / burst test
Surge test
Radiated emission
CEI61000-4-2
CEI61000-4-4
CEI61000-4-5
EN55022
Approvals
ROHS
EC
2002/95/CE
Connecting
With Molex connector ref: 43025-0800
Output cable, UL style 2464 80°C 300V - 8 wires AWG24
Input: ON/OFF
1 - Green
Input: Direction
2 - Yellow
Input: Torque limit
3 - Blue
Input: Speed
4 - Orange
0V
5 - Black
Output: Pulse
6 - Brown
Output: Torque limit reached
7 - Purple
Output: Direction
8 - Red
Power supply cable
Cable UL style 2517 105°C 300V - 2 wires AWG16 - 500 mm
+ 12Vdc -> + 32 Vdc
Brown
0V
Blue
Notes
Values without tolerences are average production values.
Added informations are in "TNI21 manual and security" on www.crouzet.com
Motor not protected in case of reversed power voltage
(1) Cold motor, 20 ° C ambient temperature, full speed
(2) Max torque for continuous operation at 20 ° C, decrease this value for higher ambient
temperature
(3) Continuously rated torque, zero radial and axial loads
(4) Pinion or pulley fitting are done at the Crouzet factory, before final assembly.
Specifications subject to change without notice. Updated july 8, 2013.
Crouzet Automatismes
2 rue du Docteur Abel CS0059
26902 Valence CEDEX 9 France
www.crouzet.com
Series 80 140 TNI21
Max. output speed
Current at the max output speed
Standby current
0/10 V
0/10 V
Speed
Torque
At no load
Drive electrical datas
Max. product characteristics
Input datas
Parameters
Max. voltage supply "Vcc"
Max. current "Icc max"
Max. voltage on inputs "Vin max"
Max. voltage on outputs "Vout max"
Max. output current "Iout max"
Parameters
Impedance - Input 1, 2
Impedance - Input 3, 4
Low level - Input 1, 2
HIgh level - Input 1, 2
Low level - Input 3, 4
High level - Input 3, 4
PWM frequency
Vdc
A
Vdc
Vdc
mA
39
12
39
39
50
Running datas
Parameters
Voltage suplly "Vcc"
Current "Icc"
Standby power "Wo"
Speed setting
Torque setting
Holding torque setting
Min
10
120
35
35
Vdc
A
W
rpm
mNm
mNm
Typical
12/24/32
6
2
Max
36
12
4000
360
150
kΩ
kΩ
Vdc
Vdc
Vdc
Vdc
Hz
Min
100
Typical
57
69
Max
2
39
2
39
2000
Min
Typical
Max
0,2
Vcc - 0,5
Vcc
Output datas
Parameters
Vdc
Low level Outputs
with "pull down resistor" = 4,7KΩ and Vcc = 24 V
Vdc
High level Outputs
= voltage supply added from eventual rejective voltage
Speed-torque and current-torque curves
4500
10
3500
24 V
3000
8
2500
Current (A)
Speed (rpm)
12
32 V
4000
12 V
2000
1500
6
32 V
12 V
4
24 V
1000
2
500
200
300
Torque (mNm)
Continuous running
400
200
300
400
Torque (mNm)
Cycling
Wiring
Nominal torque
Peak torque
Output equivalent circuit
Outputs
PNP open collector output with internal current limitation (50mA)
Add a pull down resistor
ON /OFF
1
Brushless motor
6
Encoder pulse
Direction
2
TNI21
7
Max. torque reached
8
Real direction
Torque
3
Speed
4
0 Volt
5
Vcc
Output
0 Volt
Pull down resistor
4kW7
12 -> 32 Vdc
0 Volt
Inputs: Torque and Speed
Inputs: ON/OFF and Direction
Input
Input
0 Volt
0 Volt
www.crouzet.com
Series 80 140 TNI21
很抱歉,暂时无法提供与“80140051”相匹配的价格&库存,您可以联系我们找货
