Additional Resources:
Product Page
date
08/22/2012
page
1 of 5
SERIES: VGS-100 │ DESCRIPTION: AC-DC POWER SUPPLY
U
up to 110 W continuous power
compact footprint
universal input (88~264 Vac / 125~373 Vdc)
single output from 3.3 to 48 V
over voltage, over load, and short circuit protections
UL/cUL and TUV safety approvals
long life electrolytic capacitors
no load power consumption < 0.5 W
efficiency 89%
RoHS
(Vdc)
VGS-100-3.3
3.3
VGS-100-5
5
output
current
output
power
ripple and
noise
max
(W)
max
(mVp-p)
TI
output
voltage
MODEL
N
ED
FEATURES
max
(A)
efficiency
100
70
16
80
100
80
8.5
102
120
86
7
105
120
88
12
VGS-100-15
15
VGS-100-24
24
4.5
108
120
88
VGS-100-48
48
2.3
110
200
89
O
N
VGS-100-12
VGS-100 - XX
Base Number
Output Voltage
D
IS
C
PART NUMBER KEY
cui.com
Product Page
CUI Inc │ SERIES: VGS-100 │ DESCRIPTION: AC-DC POWER SUPPLY
date 08/22/2012 │ page 2 of 5
INPUT
conditions/description
min
voltage range
frequency range
current
at 115 Vac, cold start
at 230 Vac, cold start
inrush current
at 230 Vac, full load, cold start
max
units
88
125
264
373
Vac
Vdc
50
60
Hz
2.5
1.4
A
A
40
A
max
units
OUTPUT
parameter
min
±10
line regulation
low line to high line
load regulation
3.3 V models
5 V models
all other models
start-up time
rise time
hold-up time
isolation voltage
input to output:
input to case:
output to case:
EMI/EMC
±0.5
±2.0
±1.0
±0.5
1.0
0.8
s
s
65
50
ms
ms
min
ms
ms
nom
max
4,242
2,121
707
units
Vdc
Vdc
Vdc
UL 60950-1 / TUV EN 60950-1
EN 55022 : 1998+A1 : 2000+A2 : 2003 Class B, EN 61000-3-2 : 2000+A2 : 2005 Class A, EN 610003-3 : 1995+A1 : 2001, EN 61204-3 : 2000 EN 50204 1998+A1 : 2001+A2 : 2003 light industry level,
criteria A
measured per IEC 60950-1, paragraph 5.1,
test voltage of 240 Vac/60 Hz
IS
C
leakage current
O
parameter
±3
±2
±1
10
32
N
SAFETY & COMPLIANCE
N
3.3 V models
5 V models
all other models
TI
voltage tolerance
safety approvals
nom
U
voltage adjust
nom
ED
parameter
RoHS compliant
yes
MTBF
at 230 Vac, MIL-HDBK-217F 25 °C ambient
2
620,300
mA
hrs
ENVIRONMENTAL
parameter
min
operating temperature
see derating curve
storage temperature
see derating curve
non-condensing operating
(0 ~ 50°C)
vibration
(10 ~ 500 Hz, 1 hour per axis, 3 hours total)
D
relative humidity
temperature coefficient
cui.com
nom
max
units
-20
70
°C
-40
85
°C
90
0.3
%/°C
5
Grms
Product Page
date 08/22/2012 │ page 3 of 5
PROTECTIONS
parameter
over load
Hiccup mode, auto recovery
latch off mode
short circuit
continuous
115
DERATING CURVES
Load vs. Temp
max
units
110
150
Load vs. Input Voltage
60
40
U
80
80
60
40
N
Load factor ( %)
100
40 50 60 70
100
110
120
Input Voltage Vac
N
TI
Ambient temperature (°C)
90
O
-25
D
IS
C
Load factor ( %)
nom
ED
over voltage
min
cui.com
264
Product Page
date 08/22/2012 │ page 4 of 5
MECHANICAL DRAWING
Note:
terminal block screws #6-32 (7 PLCS)
ED
Tolerance: ±0.3mm unless otherwise
specified
C
129.50 5.098
0.35
9.50 0.374
(6 PLCS)
L
N
GND
U
-V
97.50 3.839
-V
+V
6.50 0.256
N
+V
C
120.00 4.724
0.35
3.50 0.138
TI
8.30 0.327
(7 PLCS)
3.50 0.138
9.00 0.354
18.10 0.713
9.00 0.354
37.50 1.476
18.50 0.728
78.00 3.071
(2 PLCS)
M3
(2 PLCS)
O
4.50 0.177
IS
C
3.50 0.138
10.00 0.394
M3
(3 PLCS)
N
77.00 3.031
(2 PLCS)
33.00 1.299
86.00 3.386
30.75 1.211
6.50 0.256
D
2.00 0.079
33.00 1.299
cui.com
Product Page
date 08/22/2012 │ page 5 of 5
REVISION HISTORY
description
date
1.0
initial release
08/12/2011
1.01
V-Infinity branding removed
ED
rev.
08/22/2012
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“VGS-100-48”相匹配的价格&库存,您可以联系我们找货
