PW1.5
PW1.5
    C-TON
    AC/DC CONVERTER 24V 36W
PW1.5 数据手册
Specifications Installation and Operating Instructions PW1.5 DC Power Supply DESCRIPTION & FEATURES The PW 1.5 is a regulated 1.5 amp power supply that accepts 24 VDC/VAC and provides an adjustable 1.5 to 29VDC output. Field voltage adjustments may be made using only a screwdriver. The power supply is provided with a mounting track for easy installation. }} }} }} }} SPECIFICATIONS VOLTAGE Input : Output: ORDERING INFO Output Current: Temperature Stability: Over-current Protection: 24 VAC, 50/60 Hz 24 VDC (full wave rectified and regulated) adjustable 1.5 V - 27 VDC 1.5 amps (with 75 VA transformer) 1% 3 amp fuse Operating Temperature: Max. Humidity: 0 to 55°C (32° to 130°F) 95% RH, noncondensing Weight: 0.4 lb. snap-track included ENVIRONMENT PHYSICAL MOUNTING Low cost Regulated DC output Snap-track mounted Screw terminals with pressure plates PART NUMBER PW1.5 OUTPUT CURRENT: ISOLATION: EXAMPLE: If the AC and DC circuit grounds cannot be isolated move the shorting jumper from J1 to J2 and add a shorting jumper to J3. To prevent overheating the PW 1.5 power supply, the output current must not exceed the ratio of the output voltage to the input voltage times the rated current. For an output voltage set to 5VDC the output current should not exceed 313 mA. 5V x 1.5A = 0.313A 24V If the DC ground is connected to the AC ground the fuse will open. In this case the maximum output current is reduced to 400mA. DIMENSIONS & WIRING J1 J2 J3 OUTPUT VOLTAGE ADJUSTMENT + REGULATED DC VOLTAGE OUTPUT 24VAC IN LINE VOLTAGE TRANSFORMER C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
PW1.5 价格&库存
很抱歉,暂时无法提供与“PW1.5”相匹配的价格&库存,您可以联系我们找货
