Additional Resources:
Product Page
date
11/03/2020
page
1 of 6
U
ED
SERIES: VOF-280 Ϳ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
output
voltage
output
power1
ripple
and noise2
HϒFLHQF\3
max
(A)
max
(W)
max
(mVp-p)
W\S
23.33
280
120
88
18.67
280
150
90
11.67
280
240
90
36
7.78
280
360
90
48
5.84
280
480
91
(Vdc)
12
VOF-280-15
15
VOF-280-24
24
N
VOF-280-12
output
current
TI
MODEL
N
• up to 280 W continuous power
• universal input voltage range
• industry standard 3” x 5” footprint
• power factor correction
• low no load power consumption
• over voltage, over current, and short circuit protections
• output trim
8/F8/DQG789VDIHW\DSSURYDOV
• efficiency up to 91%
VOF-280-36
VOF-280-48
CO
Notes:
1. Maximum output power of 280 W with forced air cooling (34.2 CFM), 168 W with convection cooling.
$WIXOOORDGQRPLQDOLQSXW0+]EDQGZLGWKRVFLOORVFRSHXVLQJD´WZLVWHGSDLUZLUHWHUPLQDWHGWRJHWKHUZLWKDNj)DQGNj)FDSDFLWRU
3. At full load, 230 Vac input, without external fan.
$OOVSHFL¿FDWLRQVDUHPHDVXUHGDW7D &9DFLQSXWYROWDJHDQGUDWHGRXWSXWORDGXQOHVVRWKHUZLVHVSHFL¿HG
D
IS
PART NUMBER KEY
VOF-280 - XX
Output Voltage
Base Number
cui.com
Product Page
CUI Inc Ϳ SERIES: VOF-280 Ϳ DESCRIPTION: AC-DC POWER SUPPLY
date 11/03/2020 Ϳ page 2 of 6
INPUT
parameter
conditions/description
min
voltage
W\S
90
units
277
Vac
63
Hz
47
current
at 115 Vac, full load
at 230 Vac, full load
inrush current
at 230 Vac, cold start
leakage current
at 264 Vac
at 230 Vac
input fuse
6.3 A / 250 V time delay fuse (included)
3.5
1.7
line regulation
from 100%~10% load
transient response
1 kHz, 90%~10% load
VOF-280-12
VOF-280-15
VOF-280-24
VOF-280-36
VOF-280-48
start-up delay time
at 115 Vac
at 230 Vac
start-up rise time
at 115/230 Vac
hold-up time
at 115/230 Vac
adjustability
built in trim pot
N
TI
load regulation
min
swithching frequency
DWa&
fan output
12 Vdc / 300 mA
CO
WHPSHUDWXUHFRHϒFLHQW
W\S
80
A
3.5
mA
0.5
W
max
units
±3
±0.5
±1
1,200
1,500
2,400
3,600
4,800
mVp-p
mVp-p
mVp-p
mVp-p
mVp-p
3
2.5
s
s
60
ms
N
parameter
A
A
U
0.98
0.95
OUTPUT
initial set point accuracy
ED
frequency
max
10
ms
±5
75
400
±0.03
kHz
PROTECTIONS
parameter
min
latch mode
VOF-280-12
VOF-280-15
VOF-280-24
VOF-280-36
VOF-280-48
13.8
16.5
26.5
38.5
55
over current protection
hiccup, auto recovery
110
latch
IS
over voltage protection
W\S
max
units
15.8
19.5
31.5
43.5
62
Vdc
Vdc
Vdc
Vdc
Vdc
SAFETY & COMPLIANCE
isolation voltage
input to output
input to ground
output to ground
safety approvals
UL 60950-1, EN 60950-1, IEC 60950-1
D
parameter
min
W\S
3,000
1,500
500
cui.com
max
units
Vac
Vac
Vac
Product Page
date 11/03/2020 Ϳ page 3 of 6
SAFETY & COMPLIANCE (CONTINUED)
EMI/EMC1
EN 55022: 2010 Class B, EN 61204-3:2000, EN
61000-6-3: 2007 +A1: 2011, EN 61000-3-2:
2006 +A2: 2009, EN 61000-3-3: 2008, EN 55024:
2010, EN 61000-6-1: 2007, ENV 50204: 1995, CE,
FCC
class
class I
07%)
as per MIL-HDBK-217F
RoHS
2011/65/EU
1RWHV
min
250,000
max
units
hours
7KHSRZHUVXSSO\LVFRQVLGHUHGDFRPSRQHQWZKLFKZLOOEHLQVWDOOHGLQWR¿QDOHTXLSPHQW7KH¿QDOHTXLSPHQWVWLOOPXVWEHWHVWHGWRPHHWWKHQHFHVVDU\(0&GLUHFWLYHV
parameter
operating temperature
see derating curves
U
ENVIRONMENTAL
min
non-condensing
storage humidity
non-condensing
N
-40
operating humidity
operating altitude
DERATING CURVES
with FAN 34.2 CFM
80
40
without FAN
CO
50
40
50
units
70
85
90
90
5000
m
2
G
60
Ta=25°C
100
90
Load (%)
100
max
Temperature Derating Curve
Load vs. Input Voltage
N
Load vs. Temperature
TI
10~3000Hz, 10 minutes per cycle, for 1 hour
along each of the X, Y, and Z axes
vibration & shock
60
W\S
-20
storage temperature
Load (%)
W\S
ED
parameter
80
60
40
70
Ambient Temperature (°C)
100
110
D
IS
Input Voltage (Vac)
cui.com
120
277
Product Page
date 11/03/2020 Ϳ page 4 of 6
EFFICIENCY CURVES
95
95
93
93
91
91
89
89
87
85
83
79
40
50 60
70
80
Load Current (%)
230 Vac
90
100
10
40
50
60
70
80
Load Current (%)
90
100
92)(ϒFLHQF\&XUYH
(ϒFLHQF\YV/RDG&XUUHQWDW9DF
TI
93
91
87
N
85
83
81
79
40
50
60
70
80
Load Current (%)
90
95
93
91
89
87
85
D
83
81
230 Vac
77
10
40
50
60
70
80
Load Current (%)
90
87
85
83
81
230 Vac
79
75
100
92)(ϒFLHQF\&XUYH
79
89
77
IS
C
10
O
230 Vac
77
Efficiency (%)
91
89
75
75
95
93
Efficiency (%)
81
N
10
95
Efficiency (%)
83
77
92)(ϒFLHQF\&XUYH
75
85
79
230 Vac
77
75
87
U
81
ED
92)(ϒFLHQF\&XUYH
Efficiency (%)
Efficiency (%)
92)(ϒFLHQF\&XUYH
100
cui.com
10
40
50
60
70
80
Load Current (%)
90
100
Product Page
date 11/03/2020 Ϳ page 5 of 6
MECHANICAL
parameter
dimensions
127 x 76.2 x 39.6
min
external fan
AC input
CN1 mates with Molex 09-50-7031 housing with
Molex 2478 series crimp contact or equivalent
DC output
CN2 mates with Molex 09-50-7101 housing with
Auxiliary (Fan) output
)DQPDWHVZLWK-67;+3KRXVLQJZLWK-67
6;+73FRQWDFWRUHTXLYDOHQW
N
units: mm [inch]
tolerance: ±0.3 mm
FAN
Function
1
L
2
13
3
N
CN2
Function
1
+Vo
2
+Vo
3
+Vo
4
+Vo
9
10
CO
3,1
N
3,1
TI
CN1
8
kg
U
MECHANICAL DRAWING
7
units
ED
0.36
cooling
6
max
mm
weight
5
W\S
+Vo
-Vo
-Vo
-Vo
-Vo
-Vo
IS
CN3 (FAN)
Function
1
+FAN
2
-FAN
D
3,1
cui.com
1 2
CN3
FAN CONNECTOR
Product Page
date 11/03/2020 Ϳ page 6 of 6
REVISION HISTORY
description
date
1.0
initial release
1.01
DGGHGHϒFLHQF\FXUYHV
1.02
company logo updated
U
ED
rev.
06/27/2016
09/27/2016
11/03/2020
D
IS
CO
N
TI
N
7KHUHYLVLRQKLVWRU\SURYLGHGLVIRULQIRUPDWLRQDOSXUSRVHVRQO\DQGLVEHOLHYHGWREHDFFXUDWH
Headquarters
20050 SW 112th Ave.
7XDODWLQ25
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
&8,RϑHUVDWZR\HDUOLPLWHGZDUUDQW\&RPSOHWHZDUUDQW\LQIRUPDWLRQLVOLVWHGRQRXUZHEVLWH
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
OLIHVXSSRUWGHYLFHRUV\VWHPZKRVHIDLOXUHWRSHUIRUPFDQEHUHDVRQDEO\H[SHFWHGWRFDXVHWKHIDLOXUHRIWKHOLIHVXSSRUWGHYLFHRUV\VWHPRUWRDϑHFWLWVVDIHW\RUHϑHFWLYHQHVV
很抱歉,暂时无法提供与“VOF-280-12”相匹配的价格&库存,您可以联系我们找货
