PW2-24
PW2-24
    C-TON
    Linear AC DC Converter 1 Output 24V 100mA 120VAC Input
PW2-24 数据手册
Specifications Installation and Operating Instructions PW-2 DC Power Supply DESCRIPTION & FEATURES The PW2 converts AC line voltage to regulated DC output. This compact power supply may be used to power various DC operated peripherals and inputs/output modules on PLCs or transmitters in process control. }} }} }} }} }} SPECIFICATIONS VOLTAGE Input : Output: Regulated power outputs of 5 VDC, 12 VDC and 24 VDC 120V/60Hz Input Screw terminal connections Easily mounted in any plane Output DC voltages are isolated from AC line ORDERING INFO PART NUMBER 120 VAC ± 5% / 60 Hz (external fuse recommended) 5 V ± 0.2 VDC @ 300 mA 12 V ± 0.5 VDC @ 200 mA 24 V ± 1 VDC @ 100 mA INPUT PW2-12...................................... 120 AC...........................12 VDC @ 200mA PW2-24...................................... 120 AC...........................24 VDC @ 100mA ENVIRONMENT Operating Temperature: 0 to 55°C (32 to 130°F) Max. Humidity: 95% RH, noncondensing PHYSICAL Weight: MOUNTING 0.38 lb. side or base DIMENSIONS C-TON Industries OUTPUT PW2-5........................................ 120 AC.............................5 VDC @ 300mA • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
PW2-24 价格&库存
很抱歉,暂时无法提供与“PW2-24”相匹配的价格&库存,您可以联系我们找货
