26450100
26450100
    CROUZET(高诺斯)
    POWER SUPPLY ACC DIN RAIL PLATE
26450100 数据手册
16/12/2011 www.crouzet.com "Millenium Supply" switch mode power supply 89450 with PFC Part number 89450242 Electronic and regulated 85 to 264 VAC input Conforms to global standards Incorporated thermal protection PFC filter option Certifications Conformity to standards Output circuit Status indication Operating voltage (Ue) Nominal output current (A) Output voltage accuracy Line and load regulation Residual ripple Protection against short circuits Protection against voltage surges Thermal protection Input circuit Nominal voltage (V) Current consumption (mA) Operating characteristics Connection capacity Ambient storage temperature (°C) Relative humidity Vibrations Temperature Use (°C) MTBF Generic immunities Immunity to electrostatic discharges Immunity to electromagnetic discharges Immunity to conducted disturbances Immunity to mains supply disturbances Incorporated input fuse Emission Connections Dielectric strength Generic: UL 508, CSA 22.2 no. 60950 Safety: IEC/EN 60950-1 EMC: EN 61000-6-3, EN 61000-6-2 LF harmonic currents: EN 61000-3-2 Green LED *** TRADUCTION MANQUANTE *** 5 - 8.3 at 12 V and 2.5 - 4.2 - 6.2 - 10 at 24 V ± 10% ± 3% < 200 mV Continuous, automatic restart U > 1, 2U out Yes 100→240 VAC (60 and 100W), 115/230 VAC (150 and 240W) Ue = 240 2 A (60W) - 0,7 A (100W) - 2,5 A (150W) - 3 A (240W) Ue = 100 2 A (60W) - 1,4 A (100W) - 5 A (150W) - 6 A (240W) Input: 2 x 4 mm² + earth Output: 2 x 4 mm² (60W) ; doubled for 100, 150 and 240W -25→+85 20→90% RH Conforming to EN 61131-2 Voir courbes de déclassement >100,000 hr at 100% load (at 40°) Conforming to IEC 61000-6-2 Conforming to IEC 61000-4-2 level 3 (4 kV contact/8 kV air) Conforming to IEC 61000-4-3 level 3 (10V/m) Conforming to IEC 61000-4-4 level 3 (2 kV), EN 61000-4-5, EN 61000-4-6 level 3, EN 61000-4-8 level 4, IEC/EN 61000-4-12 level 3 Conforming to IEC/EN 61000-4-11 (voltage dips and interruptions) Yes Generic: conforming to EN 61000-6-3 Conducted/radiated: conforming to EN 55011, EN 55022 c1B Input/output: 3000AC 50/60 Hz 1 min Input/earth: 1500AC 50/60 Hz 1 min Output/earth: 500AC 50/60 Hz 1 min Description Weight (kg) Code Mounting bracket Snap-on plate for 35 mm DIN rail 0.085 0.035 26450100 26450101 Dimension Diagram : 89450 power supplies Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 16/12/2011 www.crouzet.com No Legend 1 2 3 *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** Dimension Diagram : Mounting bracket Dimension Diagram : Snap-on plate No Legend 1 *** TRADUCTION MANQUANTE *** Curves : *** TRADUCTION MANQUANTE *** Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 16/12/2011 www.crouzet.com No Legend 1 *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** Curves : *** TRADUCTION MANQUANTE *** No Legend *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** *** TRADUCTION MANQUANTE *** : 89 450 122 - 89 450 222 - 89 450 232 - 89450 242 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 16/12/2011 www.crouzet.com No Legend 1 PFC filter Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
26450100 价格&库存
很抱歉,暂时无法提供与“26450100”相匹配的价格&库存,您可以联系我们找货
