P804-010
P804-010
    TRIPPLITE
    P804-010
P804-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Cable, 10-ft. Interlink Parallel File Transfer Cable DB25M to DB25M MODEL NUMBER: P804-010 Highlights ● Gold-plated connectors provide superior conductivity System Requirements ● Two computers with parallel ports ● File transfer software Package Includes ● Description Tripp Lite's interlink parallel cable is used to transfer files between two computers via the parallel ports. This 10-ft. cable features DB25 male gold connector on each end. Gold plated connectors and gold plated copper contacts offer superior conductivity. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Connects two computers together via their parallel ports for file transferring purposes. ● Superior molded design with ergonomic thumbscrews strain relief and durable PVC pre-mold and cable jacket ● 10-ft. file transfer cable ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Features gold-plated connectors for superior conductivity and support of high-speed applications ● Connectors: DB25 male to DB25 male ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332014566 PHYSICAL Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 12.00 x 7.00 x 0.75 1/2 10-ft. Interlink Parallel File Transfer Cable DB25M to DB25M Gold Connectors 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 30.48 x 17.78 x 1.90 Shipping Weight (lbs.) 0.52 Shipping Weight (kg) 0.24 CONNECTIONS Side A - Connector 1 DB25 (MALE) Side B - Connector 1 DB25 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P804-010
物料型号:P804-010
器件简介:Tripp Lite的互连并行电缆用于通过并行端口在两台计算机之间传输文件。
这款10英尺的电缆两端各有一个DB25公头,镀金连接器和镀金铜接触提供优越的导电性。
引脚分配:DB25公头到DB25公头
参数特性: - 电缆长度:10英尺(3.05米) - 包装尺寸:12.00 x 7.00 x 0.75英寸(30.48 x 17.78 x 1.90厘米) - 包装重量:0.52磅(0.24公斤) - UPC代码:037332014566 - 连接器:DB25公头
功能详解:连接两台计算机的并行端口以进行文件传输,具有优越的模制设计,包括符合人体工程学的拇指螺丝、抗拉力和耐用的PVC预模制和电缆套。
应用信息:用于需要通过并行端口在计算机之间传输文件的场合。
封装信息:镀金连接器,支持高速应用,提供优越的导电性和EMI/RFI防护。
此外,Tripp Lite为其产品提供终身有限保修。
P804-010 价格&库存
很抱歉,暂时无法提供与“P804-010”相匹配的价格&库存,您可以联系我们找货
