P710-006
P710-006
    TRIPPLITE
    P710-006
P710-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States IEEE 1284 AA Straight Through Cable (DB25 M/M), 6-ft. MODEL NUMBER: P710-006 Highlights ● IEEE rated to support IEEE 1284 compatible auto switches ● Fully shielded against EMI/RFI interference System Requirements ● Computer with a parallel port DB25 Female ● Parallel device or switchbox with a DB25 Female port requiring IEEE communication Package Includes ● Description Tripp Lite's 6-ft. IEEE 1284 straight through cable connects a computer to a manual or automatic switchbox. It supports high-speed IEEE 1284 bi-directional communication. The cable features nickel plated DB25 male/male connectors and gold plated copper contacts for superior conductivity. It is manufactured from superior molded cable with integral strain relief and double shielding for maximum EMI/RFI protection. It contains low-capacitance, impedance matched, twisted-pair conductors that protect against cross-talk and other transmission problems. Features ● Connects a computer to a manual or automatic switchbox ● Supports high-speed IEEE 1284 bi-directional communication (modes: standard compatible nibble byte ECP and EPP) ● Length: 6-ft. Connectors: DB25 male/male ● Nickel plated connectors and gold plated copper contacts offer superior conductivity ● Superior molded cable with integral strain relief and double shielding (foil and braid) for maximum EMI/RFI protection ● Low-capacitance impedance matched twisted-pair conductors protect against cross-talk and other transmission problems ● 25 conductor (direct wired) ● Molded ends with easy-grip textured overmold Specifications OVERVIEW UPC Code 037332014436 Technology Parallel 1/2 6-ft. IEEE 1284 AA Straight Thru Parallel Cable DB25M to DB25M 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 CONNECTIONS Side A - Connector 1 DB25 (MALE) Side B - Connector 1 DB25 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P710-006
物料型号为 P710-006,是 Tripp Lite 公司生产的 6 英尺 IEEE 1284 AA 直通并口电缆。
该电缆用于连接计算机和手动或自动开关盒,支持高速 IEEE 1284 双向通信。
电缆具有以下特点:
- 全屏蔽设计,有效抵抗电磁干扰(EMI/RFI)。
- 连接器为镍镀 DB25 公/公,提供优越的导电性。
- 电缆采用优质材料制造,具有整体抗拉设计和双层屏蔽(箔和编织层),为最大程度的 EMI/RFI 保护。
- 包含低电容、阻抗匹配的双绞线导体,减少串扰和其他传输问题。
- 25 根导体直接布线,易于握持的模压端头。
电缆规格包括黑色,长度为 6 英尺(1.83 米),运输尺寸和重量也已列出。
产品提供全球范围内的有限终身保修。
更多详细信息和支持可访问 Tripp Lite 官网。
P710-006 价格&库存
很抱歉,暂时无法提供与“P710-006”相匹配的价格&库存,您可以联系我们找货
