P402-006-R
P402-006-R
    TRIPPLITE
    P402-006-R
P402-006-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Serial Modem Gold Cable (F/M) 6-ft. Highlights ● Superior molded cables with foilshielding for maximum EMI/RFI protection ● Gold-plated connectors provide superior conductivity ● Null modem cables connect two serial devices that require a null modem configuration ● Retail packaging MODEL NUMBER: P402-006-R System Requirements ● External modem with a Female DB25 port ● Computer with an available DB25 serial port Package Includes ● Description 6 foot PC serial modem cable. DB25 female to DB25 male. Superior molded cables with built-in strain relief ensures the cable will last a very long time. Foil-shielding provide maximum EMI/RFI protection. Gold plated connectors and gold plated copper contacts offer superior conductivity. Clamshell retail packaging. Features ● Superior molded cables with built-in strain relief ensures cable will last a very long time ● Foil-shielding provide maximum EMI/RFI protection ● Gold plated connectors and gold plated copper contacts offer superior conductivity ● Pins 1 - 8, 20, 22 Specifications OVERVIEW UPC Code 037332012173 PHYSICAL Color Black Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 6.75 x 5.75 x 2.00 Shipping Dimensions (hwd / cm) 17.14 x 14.60 x 5.08 Shipping Weight (lbs.) 0.51 Shipping Weight (kg) 0.23 1/2 6-ft. Serial Modem Gold Cable DB25F to DB25M 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 DB25 (FEMALE) Side B - Connector 1 DB25 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P402-006-R
物料型号: - 型号编号:P402-006-R
器件简介: - 该产品是一款6英尺长的串行调制解调器金线缆,一端为DB25母头,另一端为DB25公头。线缆采用优质模制材料,内置抗拉设计,确保线缆经久耐用。箔屏蔽提供最大的EMI/RFI保护,镀金连接器和镀金铜接触提供优越的导电性。采用蛤壳式零售包装。
引脚分配: - 引脚1-8、20、22
参数特性: - UPC代码:037332012173 - 连接:侧A - 连接器1为DB25(母头),侧B - 连接器1为DB25(公头) - 物理特性:颜色为黑色,线缆长度为6英尺(1.83米),发货尺寸为6.75x5.75x2.00英寸,发货尺寸为17.14x14.60x5.08厘米,发货重量为0.51磅(0.23千克)
功能详解: - 线缆具有内置抗拉设计,确保线缆经久耐用。 - 箔屏蔽提供最大的EMI/RFI保护。 - 镀金连接器和镀金铜接触提供优越的导电性。
应用信息: - 适用于需要无调制解调器配置的两个串行设备之间的连接。
封装信息: - 产品提供蛤壳式零售包装。 - 提供终身有限保修。
P402-006-R 价格&库存
很抱歉,暂时无法提供与“P402-006-R”相匹配的价格&库存,您可以联系我们找货
