P702-006-R
P702-006-R
    TRIPPLITE
    P702-006-R
P702-006-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Switch - 6 ft. RS232 Straight Through Gold Cable DB25M/M MODEL NUMBER: P702-006-R Highlights ● 25 conductor straight through cables designed for use with printer switches ● Gold-plated connectors provide superior conductivity ● Superior molded cables with foilshielding maximum EMI/RFI protection System Requirements ● Computer with a parallel port DB25 Female ● Parallel device or switchbox with a DB25 Female port Package Includes ● Description Tripp Lite's 6-ft. straight through gold switch cable connects a computer to either a manual or automatic switchbox. The cable features a superior molded design to ensure that the cable lasts a long time. Goldplated connectors and contacts offer superior conductivity. Aluminum foil shielding reduces line noise. Note: use Tripp Lite's IEEE 1284 straight through gold switch cable (P710-006 P710-010 or P710-020) for IEEE 1284 bitronics switches. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Clamshell retail package. Features ● Connects a computer to either a manual or automatic switchbox ● Aluminum foil shielding reduces line noise ● Superior molded design with ergonomic thumbscrews strain relief and durable PVC pre-mold and cable jacket ● Superior molded cables with foil-shielding for maximum EMI/RFI - Protection ● Gold plated connectors and gold plated copper contacts offer superior conductivity and support of highspeed applications ● Connector types: DB25 (male) to DB25 (male) ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332014368 PHYSICAL Cable Length (ft.) 6 Cable Length (m) 1.83 1/2 6-ft. Straight Thru Parallel Gold Cable DB25M to DB25M 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 7.50 x 7.25 x 2.25 Shipping Dimensions (hwd / cm) 19.05 x 18.42 x 5.72 Shipping Weight (lbs.) 0.77 Shipping Weight (kg) 0.35 CONNECTIONS Side A - Connector 1 DB25 (MALE) Side B - Connector 1 DB25 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P702-006-R
物料型号: - 型号编号:P702-006-R
器件简介: - Tripp Lite的6英尺直线型金插头RS232电缆,用于连接计算机至手动或自动切换盒。该电缆采用优质模制设计,确保长久耐用。镀金连接器和接触点提供优越的导电性,铝箔屏蔽减少线路噪音。
引脚分配: - 连接器类型:DB25(公头)至DB25(公头)
参数特性: - 镀金连接器和镀金铜接触点提供优越的导电性和对高速应用的支持。 - 铝箔屏蔽减少线路噪音,提供最大EMI/RFI保护。 - 模制设计具有符合人体工程学的拇指螺丝、防拉伤和耐用的PVC预模和电缆套。
功能详解: - 连接计算机至手动或自动切换盒。 - 铝箔屏蔽减少线路噪音。 - 模制设计具有符合人体工程学的拇指螺丝、防拉伤和耐用的PVC预模和电缆套。
应用信息: - 用于连接计算机至打印机切换盒,适用于IEEE 1284位元逻辑开关。
封装信息: - 包装包括6英尺直线型并行金电缆DB25M至DB25M。 - Tripp Lite对该产品提供终身材料和工艺缺陷保修。
P702-006-R 价格&库存
很抱歉,暂时无法提供与“P702-006-R”相匹配的价格&库存,您可以联系我们找货
