P404-006-R
P404-006-R
    TRIPPLITE
    P404-006-R
P404-006-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Cable, 6-ft. AT Serial Gold Snagless Cable DB25M to DB9F MODEL NUMBER: P404-006-R Highlights ● Superior molded cables with foilshielding for maximum EMI/RFI protection ● Gold-plated connectors provide superior conductivity ● Null Modem cables connect two serial devices that require a null modem configuration ● Retail packaging System Requirements ● Hayes compatible external modem with a Female DB9 port ● Computer with an available DB25 serial port Package Includes ● Description 6ft serial modem cable. DB25M to DB9F. Superior molded cables with built-in strain relief ensures the cable will last a very long time. Foil-shielding provide maximum EMI/RFI protection. Gold plated connectors and gold plated copper contacts offer superior conductivity. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Clamshell retail packaging. Features ● Superior molded cables with built-in strain relief ensures cable will last a very long time ● Foil-shielding provide maximum EMI/RFI protection ● Gold plated connectors and gold plated copper contacts offer superior conductivity ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332012203 PHYSICAL Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 6.75 x 5.75 x 2.00 Shipping Dimensions (hwd / cm) 17.14 x 14.60 x 5.08 Shipping Weight (lbs.) 0.46 Shipping Weight (kg) 0.21 1/2 6-ft. Gold Modem Cable DB25M to DB9F 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 DB9 (FEMALE) Side B - Connector 1 DB25 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P404-006-R
物料型号: - 型号编号:P404-006-R
器件简介: - 该产品为6英尺长的AT串行金插头抗缠绕电缆,一端为DB25M公头,另一端为DB9F母头。具有优越的模具制造工艺和内置的抗拉保护,确保电缆经久耐用。提供箔屏蔽以实现最大的EMI/RFI保护。镀金连接器和镀金铜接触提供优越的导电性。Tripp Lite保证此产品在材料和工艺上终身无缺陷。
引脚分配: - Side A - Connector 1: DB9(FEMALE) - Side B - Connector 1: DB25(MALE)
参数特性: - UPC代码:037332012203 - 电缆长度:6英尺(约1.83米) - 发货尺寸:6.75x5.75x2.00英寸 / 17.14x14.60x5.08厘米 - 发货重量:0.46磅 / 0.21千克 - 产品保修期限:全球范围内的有限终身保修
功能详解: - 优越的模具电缆与内置抗拉保护,确保电缆经久耐用。 - 箔屏蔽提供最大的EMI/RFI保护。 - 镀金连接器和镀金铜接触提供优越的导电性。 - Tripp Lite终身保修,保证产品无材料和工艺缺陷。
应用信息: - 适用于Hayes兼容的外部调制解调器,该调制解调器具有女性DB9端口。 - 适用于具有可用DB25串行端口的计算机。
封装信息: - 零售包装为蛤壳式。
P404-006-R 价格&库存
很抱歉,暂时无法提供与“P404-006-R”相匹配的价格&库存,您可以联系我们找货
