1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA Coax Monitor Extension Cable, Plenum
Rated High Resolution Cable with RGB Coax
(HD15 M/F), 100-ft.
MODEL NUMBER: P500-100-P
Highlights
UL Listed, CMP rated cable
Superior molded cables with foil
and braid shielding for maximum
EMI/RFI protection
Constructed from 75ohm minicoax (RGB) and paired video
wire construction for superior
signal quality
Gold plated connectors and gold
plated copper contacts
System Requirements
Monitor with HD15 cable
Package Includes
Description
Tripp Lite's Plenum Rated SVGA Extension cable is ideal in Educational or Commercial installations
where local fire codes call for a CMP rated cable to run through walls, ceilings, and plenum air chambers.
100ft distance is achieved through high quality construction: 75ohm Coaxial conductors for Red, Green,
and Blue (RGB) signals, each protected by a 93% tinned copper braid shield. An overall shiled of Mylar
foil and 85% Copper Braid shield ensures maximum signal integrity.
Features
Superior molded cables with foil and braid shielding for maximum EMI/RFI protection
UL Listed, CMP Rated Cable Jacket
Constructed from mini-coax (RGB) and paired video wire construction for superior signal quality
Resolution supported for VGA, SVGA, XGA, SXGA, UXGA, QXGA
Gold plated connectors and gold plated copper contacts ensure excellent conductivity
HD15 male to HD15 female molded connectors
Specifications
OVERVIEW
UPC Code
037332129192
PHYSICAL
Color
Black
Cable Length (ft.)
100
Cable Length (m)
30.49
1/2
100-ft. Plenum Rated
XVGA/SVGA/VGA Monitor
Extension Cable HD15M to
HD15F Gold Connectors w/
RGB Coax
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
17.00 x 14.00 x 3.00
Shipping Dimensions (hwd / cm)
43.18 x 35.56 x 7.62
Shipping Weight (lbs.)
2.90
Shipping Weight (kg)
1.32
CONNECTIONS
Side A - Connector 1
HD15 (MALE)
Side B - Connector 1
HD15 (FEMALE)
Latching or Gripping Connector
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P500-100-P”相匹配的价格&库存,您可以联系我们找货
