P520-006-R
P520-006-R
    TRIPPLITE
    P520-006-R
P520-006-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-ft. RS-232 Serial Extension Cable (DB9 M/F) Highlights ● Superior molded cables with foilshielding for maximum EMI/RFI protection ● Retail packaging MODEL NUMBER: P520-006-R System Requirements ● Monitor with DB9 cable Package Includes ● Description This Tripp Lite cable extends a RS-232 serial cable an additional 6 feet. Foil-shielding construction provides maximum EMI/RFI protection. The DB9 female and DB9 male connectors are molded with builtin strain relief to ensure that the cable last a long time. Clamshell retail package. Features ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Connector types: ● Connector a: DB9 (male) ● Connector b: DB9 (female) Specifications OVERVIEW UPC Code 037332012395 PHYSICAL Color White Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 6.75 x 5.75 x 1.25 Shipping Dimensions (hwd / cm) 17.14 x 14.60 x 3.18 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 1/2 6-ft. RS-232 Serial Extension Cable (DB9 M/F) 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 DB9 (MALE) Side B - Connector 1 DB9 (FEMALE) Latching or Gripping Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P520-006-R
物料型号:P520-006-R
器件简介:Tripp Lite 6英尺RS-232串行扩展线(DB9公母头),具有优越的模具成型线缆和箔屏蔽,以提供最大的电磁干扰/射频干扰保护。
引脚分配:DB9公头和DB9母头连接器。
参数特性: - UPC码:037332012395 - 连接器类型: - 连接器A:DB9(公) - 连接器B:DB9(母) - 是否有锁扣或卡扣连接器:无 - 物理特性: - 颜色:白色 - 线缆长度:6英尺(1.83米)
功能详解:该线缆可以将RS-232串行线延长6英尺,具有箔屏蔽结构,提供最大的电磁干扰/射频干扰保护,DB9公头和母头连接器都配有内置的抗拉设计,以确保线缆的耐用性。
应用信息:适用于需要延长RS-232串行连接的场合。
封装信息:采用蛤壳式零售包装。
此外,该产品的发货尺寸和重量分别为6.75 x 5.75 x 1.25英寸/17.14 x 14.60 x 3.18厘米和0.40磅/0.18千克。
产品提供全球范围内的有限终身保修。
P520-006-R 价格&库存
很抱歉,暂时无法提供与“P520-006-R”相匹配的价格&库存,您可以联系我们找货
