P804-006
P804-006
    TRIPPLITE
    P804-006
P804-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-ft. Interlink Parallel File Transfer Gold Cable (DB25M/M) MODEL NUMBER: P804-006 Highlights ● Gold-plated connectors provide superior conductivity System Requirements ● Two computers with parallel ports ● File Transfer Software Package Includes ● Description Tripp Lite's interlink parallel cable is used to transfer files between two computers via the parallel ports. This 6-ft. cable features DB25 male gold connector on each end. Gold plated connectors and gold plated copper contacts offer superior conductivity. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Connects two computers together via their serial ports for file transferring purposes. ● Superior molded design with ergonomic thumbscrews strain relief and durable PVC pre-mold and cable jacket ● 10-ft. file transfer cable ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Features gold-plated connectors for superior conductivity and support of high-speed applications ● Connectors: DB9 female to DB9 female ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332014559 PHYSICAL Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 12.00 x 7.00 x 0.75 1/2 6-ft. Interlink Parallel File Transfer Cable DB25M to DB25M Gold Connectors 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 30.48 x 17.78 x 1.90 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 CONNECTIONS Side A - Connector 1 DB25 (MALE) Side B - Connector 1 DB25 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P804-006
物料型号为 P804-006。
这款6英尺长的Interlink并行文件传输金电缆(DB25M/M)具有以下特点:
- 器件简介:Tripp Lite的并行电缆用于通过并行端口在两台计算机之间传输文件。
这款6英尺长的电缆两端都配有DB25公头,镀金连接器和镀金铜接触提供优越的导电性。
- 引脚分配:两端均为DB25公头。
- 参数特性:电缆长度为6英尺(1.83米),运输尺寸为12.00 x 7.00 x 0.75英寸,运输重量为0.40磅(0.18千克)。
- 功能详解:连接两台计算机的串行端口,用于文件传输。
具有优越的模制设计,带有符合人体工程学的拇指螺丝,抗拉力和耐用的PVC预模塑和电缆套。
- 应用信息:用于文件传输,支持高速应用。
- 封装信息:镀金连接器,提供优越的导电性和支持高速应用。
Tripp Lite对这款产品提供终身有限保修。
P804-006 价格&库存
很抱歉,暂时无法提供与“P804-006”相匹配的价格&库存,您可以联系我们找货
