P452-006
P452-006
    TRIPPLITE
    P452-006
P452-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-ft. Null Modem Gold Cable, DB25F to DB25F Highlights ● Superior molded cables with foilshielding for maximum EMI/RFI protection ● Gold-plated connectors provide superior conductivity ● Null modem cables connect two serial devices that require a null modem configuration MODEL NUMBER: P452-006 System Requirements ● Two serial devices with DB25M connectors requiring a null modem (cross-wired) configuration Package Includes ● Description Null modem cables and adapters connect two serial devices that require a null modem (cross-wired) configuration. This 6ft cable has a DB25 female connector on each end. Superior molded cables with foilshielding offer maximum EMI/RFI protection. Gold-plated connectors and contacts provide superior conductivity. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● DB25 female to DB25 female ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Gold-plated connectors provide superior conductivity ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332013330 PHYSICAL Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 11.75 x 7.00 x 1.00 Shipping Dimensions (hwd / cm) 29.84 x 17.78 x 2.54 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 1/2 6-ft. Null Modem Gold Cable DB25F to DB25F 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 DB25 (FEMALE) Side B - Connector 1 DB25 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P452-006
物料型号为P452-006。
这是一款6英尺长的Null Modem Gold Cable,具有DB25F到DB25F的连接方式。
以下是该产品的中文分析:
器件简介: - 这款电缆专为需要Null Modem(交叉线)配置的两个串行设备之间的连接而设计。
- 它采用优质模制电缆,带有箔屏蔽,以提供最大的电磁干扰/射频干扰保护。
- 连接器为镀金,以提供优越的导电性。
引脚分配: - 端A - 连接器1:DB25(FEMALE) - 端B - 连接器1:DB25(FEMALE)
参数特性: - 产品型号:P452-006 - UPC码:037332013330 - 连接类型:DB25(FEMALE)到DB25(FEMALE) - 电缆长度:6英尺(约1.83米) - 运输尺寸:11.75x7.00x1.00英寸(29.84x17.78x2.54厘米) - 运输重量:0.37磅(约0.17公斤)
功能详解: - Null Modem电缆和适配器用于连接需要Null Modem(交叉线)配置的两个串行设备。
- Tripp Lite保证此产品在材料和工艺上无缺陷,提供终身保修。
应用信息: - 适用于两个具有DB25M连接器并需要Null Modem配置的串行设备。
封装信息: - 包装包括6英尺长的Null Modem Gold Cable,DB25F到DB25F。
请注意,以上信息是基于检索到的PDF文档内容的翻译和分析。
如需更详细的技术规格或购买信息,建议访问Tripp Lite官方网站或联系其客户服务。
P452-006 价格&库存
很抱歉,暂时无法提供与“P452-006”相匹配的价格&库存,您可以联系我们找货
