P806-010-R
P806-010-R
    TRIPPLITE
    P806-010-R
P806-010-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10-ft. Universal File Transfer Serial Gold Cable (DB9F-25F/DB9F-25F) MODEL NUMBER: P806-010-R Highlights ● Gold-plated connectors provide superior conductivity ● Retail packaging System Requirements ● Two computers with serial ports (DB9 or DB25) ● File Transfer Software Package Includes ● Description Tripp Lite's universal interlink serial cable is used to transfer files between computers. This 10-ft cable features both a DB9F and a DB25F gold connector on each end. Gold plated connectors and gold plated copper contacts offer superior conductivity. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Retail clamshell packaging. Features ● Connects two computers together via their serial ports for file transferring purposes. ● Universal cable - Can be used with any two serial ports, no matter which connector type (DB9 or DB25) ● Superior molded design with ergonomic thumbscrews strain relief and durable PVC pre-mold and cable jacket ● 10-ft. universal cable ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Features gold-plated connectors for superior conductivity and support of high-speed applications ● Connectors: DB9 female and DB25 female to DB9 female and DB25 female ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332014597 PHYSICAL Cable Length (ft.) 10 Cable Length (m) 3.05 1/2 10-ft. Univ File Transfer Serial File Transfer Cable DB9F and DB25F to DB9F and DB25F Gold Connectors 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 7.25 x 7.00 x 2.25 Shipping Dimensions (hwd / cm) 18.42 x 17.78 x 5.72 Shipping Weight (lbs.) 0.84 Shipping Weight (kg) 0.38 CONNECTIONS Side A - Connector 1 DB9/DB25 (FEMALE) Side B - Connector 1 DB9/DB25 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P806-010-R
物料型号:P806-010-R
器件简介:Tripp Lite的通用串行传输线,用于在两台电脑间进行文件传输。
该10英尺电缆两端分别有DB9F和DB25F的金接头。
引脚分配:DB9F和DB25F接头分别连接到DB9F和DB25F。
参数特性: - 电缆长度:10英尺(3.05米) - 运输尺寸:7.25x7.00x2.25英寸(18.42x17.78x5.72厘米) - 运输重量:0.84磅(0.38千克) - 产品保修期:全球范围内的有限终身保修 - 连接器:DB9母头和DB25母头,连接到DB9母头和DB25母头
功能详解:通过串行端口连接两台电脑以进行文件传输,支持高速应用,具有优良的EMI/RFI防护。
应用信息:适用于需要通过串行端口在电脑间传输文件的场合。
封装信息:零售包装,采用耐用的PVC预成型和电缆外皮,具有优越的成型设计,符合人体工程学的拇指螺丝,以及耐用的PVC预成型和电缆外皮。
P806-010-R 价格&库存
很抱歉,暂时无法提供与“P806-010-R”相匹配的价格&库存,您可以联系我们找货
