P806-010
P806-010
    TRIPPLITE
    P806-010
P806-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Cable, Serial Universal File Transfer Gold Cable MODEL NUMBER: P806-010 Highlights ● System Requirements Description Tripp Lite's universal interlink serial cable is used to transfer files between computers. This 10-ft cable features both a DB9F and a DB25F gold connector on each end. Gold plated connectors and gold plated copper contacts offer superior conductivity. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. ● Two computers with serial ports (DB9 or DB25) ● File Transfer Software Package Includes ● Features ● Connects two computers together via their serial ports for file transferring purposes. ● Universal cable - Can be used with any two serial ports, no matter which connector type (DB9 or DB25) ● Superior molded design with ergonomic thumbscrews strain relief and durable PVC pre-mold and cable jacket ● 10-ft. universal cable ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Features gold-plated connectors for superior conductivity and support of high-speed applications ● Connectors: DB9 female and DB25 female to DB9 female and DB25 female ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332014580 PHYSICAL Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 6.40 x 5.60 x 1.00 Shipping Dimensions (hwd / cm) 16.26 x 14.22 x 2.54 Shipping Weight (lbs.) 0.61 Shipping Weight (kg) 0.28 CONNECTIONS Side A - Connector 1 DB9/DB25 (FEMALE) Side B - Connector 1 DB9/DB25 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Gold-plated connectors provide superior conductivity Lifetime limited warranty 1/2 10-ft. Universal File Transfer Serial File Transfer Cable DB9F and DB25F to DB9F and DB25F Gold Connectors 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P806-010
物料型号: - 型号编号:P806-010
器件简介: - Tripp Lite的通用串行文件传输电缆,用于在两台计算机之间传输文件。这款10英尺长的电缆两端分别配有DB9F和DB25F的金连接器。
引脚分配: - 连接器:DB9母头和DB25母头至DB9母头和DB25母头
参数特性: - 金镀连接器和金镀铜接触提供优越的导电性。 - 通用电缆,适用于任何两种串行端口,无论哪种连接器类型(DB9或DB25)。 - 优越的模塑设计,带有符合人体工程学的拇指螺丝,抗拉力和耐用的PVC预模塑和电缆。 - 10英尺通用电缆。 - 金镀连接器,支持高速应用,提供优越的导电性和最大EMI/RFI保护。
功能详解: - 通过串行端口将两台计算机连接起来,用于文件传输。 - 可以用于任何两个串行端口,无论哪种连接器类型(DB9或DB25)。
应用信息: - 用于两台具有串行端口(DB9或DB25)的计算机之间传输文件。
封装信息: - 10英尺长的通用电缆,两端带有金连接器。
P806-010 价格&库存
很抱歉,暂时无法提供与“P806-010”相匹配的价格&库存,您可以联系我们找货
