S075-42I
S075-42I
    TRIPPLITE
    S075-42I
S075-42I 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SCSI/Fibre Channel - 42-in. Round Internal U320 5-Drive SCSI LVD/SE Cable 6Conn HD68M MODEL NUMBER: S075-42I Highlights ● Offers significant improvement in the airflow within devices, fit and management ● Can be used with all generations of SCSI devices ● Comes with U320 terminator ● Can support multiple drives System Requirements ● U320/U160 SCSI HBA (Host bus adapter card) ● Any internal SCSI drive or device requiring HD68M interface Package Includes ● Description Introducing Tripp Lite's round internal SCSI Ultra320 5-drive LVD/SE cable with an active modeconditioning T-type crimped on terminator. LVD/SE multi-mode termination enables backward compatibility to legacy single ended devices. The terminator will sense if the bus is running LVD or SE and terminate appropriately. This cable measures 42 inches in length from master to drive #5. This cable, with it new round design, is very flexible and easy to fit into the computer's case. The round shape also significantly improves the air flow around the cables - which can be of great concern with flat ribbon cables. Meets the latest SCSI specification of ANSI (American National Standards Institute). For 3-Drive Connection, see S075-31I, or, for Flat Version cables, see S063-31I and S065-42I. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Ideal for 1U servers where space is at a premium ● Round cable increases flexibility and air flow ● Length (master to drive 5): 42 inches ● Supports transfer speeds up to 320Mbps ● Connect up to 5 drives or internal devices ● HD68 male connectors ● Cable includes active mode conditioning terminator T-type LVD/SE terminator with local chip (ART IDC type) ● SCSI U320 cables include active multi-mode terminators which compensate for fluctuations in the host adapter ● Constructed with premium brand twist and flat brand cable ● UL rated cable ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest Ultra 320 to legacy SCSI-1 and every combination in between ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life 1/2 42 inch round internal U320 5Drive SCSI LVD/SE cable 6Conn HD68M with active multimode terminator 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332119414 Drives Supported 5 Technology Ribbon/Internal; SCSI PHYSICAL Color Gray Cable Length (ft.) 3.5 Cable Length (m) 1.07 Cable Length (in.) 42 Shipping Dimensions (hwd / in.) 9.00 x 6.75 x 2.00 Shipping Dimensions (hwd / cm) 22.86 x 17.14 x 5.08 Shipping Weight (lbs.) 1.16 Shipping Weight (kg) 0.53 CONNECTIONS Side A - Connector 1 HD68 (MALE) Side B - Connector 1 (3) HD68 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
S075-42I
1. 物料型号: - 型号编号:S075-42I
2. 器件简介: - Tripp Lite系列的SCSI/Fibre Channel 42英寸圆形内部U320 5驱动器SCSI LVD/SE电缆,带有6个连接器和HD68M主动多模终端器。该电缆支持所有代的SCSI设备,并且具有U320终结器,可以支持多个驱动器。
3. 引脚分配: - Side A - 连接器1:HD68(MALE) - Side B - 连接器1:(3) HD68 (MALE)
4. 参数特性: - 支持5个驱动器 - 技术:Ribbon/Internal; SCSI - 支持的传输速度高达320Mbps - 包含主动模式调节终端器T型LVD/SE终端器,具有本地芯片(ART IDC类型)
5. 功能详解: - 该电缆设计为圆形,增加了灵活性和空气流动性,非常适合空间有限的1U服务器使用。 - 电缆长度从主驱动器到驱动器5为42英寸。 - 支持连接多达5个驱动器或内部设备。 - 电缆包括主动模式调节终端器,补偿主机适配器的波动。
6. 应用信息: - 适用于需要HD68M接口的任何内部SCSI驱动器或设备。 - 系统要求U320/U160 SCSI HBA(主机总线适配器卡)。
7. 封装信息: - 颜色:灰色 - 电缆长度:3.5英尺(1.07米),42英寸 - 运输尺寸:9.00x6.75x2.00英寸,22.86x17.14x5.08厘米 - 运输重量:1.16磅(0.53千克)
S075-42I 价格&库存
很抱歉,暂时无法提供与“S075-42I”相匹配的价格&库存,您可以联系我们找货
