S054-45I
S054-45I
    TRIPPLITE
    S054-45I
S054-45I 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Internal SCSI U2/160 SCSI-LVD/SE 4-Drive Ribbon Cable with Terminator (5xHD68 M), 45-in. MODEL NUMBER: S054-45I Highlights ● Cable includes Active T-Type LVD/SE terminator ● UL-rated Amphenol brand cable ● Connects up to 5 drives System Requirements ● Wide SCSI controller card ● Internal SCSI drives and devices with HD68 Pin interface Package Includes ● Description Introducing Tripp Lite's internal SCSI Ultra2/U160 4-drive LVD ribbon cable with an active U160 terminator. This cable measures 45 inches in length and is made with twist and flat cabling. Because the cable is backwards compatible, it will support SCSI 1,2 & 3 devices such as CD-ROMs and Hard Drives. All Tripp Lite SCSI products regardless of the SCSI generation meet the latest SCSI specifications of ANSI (American National Standards Institute). Features ● Ribbon cable connects up to 4 internal SCSI drives/devices to your internal SCSI controller ● HD68 male connectors ● Cable includes active terminator ● UL rated twist and flat cable ● SCSI U160 cables include active terminators which compensate for impedance mismatches ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest ultra 320 to legacy SCSI-1 and every combination in between Specifications OVERVIEW UPC Code 037332096524 Drives Supported 4 PHYSICAL Color Gray Cable Length (ft.) 3.8 1/2 45-in. internal U160 SCSI ribbon cable 5Conn HD68M 4 drive with terminator 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (m) 1.16 Cable Length (in.) 45 Shipping Dimensions (hwd / in.) 10.00 x 6.00 x 3.00 Shipping Dimensions (hwd / cm) 25.40 x 15.24 x 7.62 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 CONNECTIONS Side A - Connector 1 INTERNAL HD68 (MALE) Side B - Connector 1 INTERNAL HD68 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
S054-45I
物料型号为 S054-45I。
器件简介:Tripp Lite 的内部 SCSI Ultra2/U160 4 驱动器 LVD 带状电缆,带有主动 U160 终结器。
该电缆长度为 45 英寸,采用扭绞和平铺线缆制成。
由于电缆向后兼容,它将支持 SCSI 1、2 和 3 设备,如 CD-ROM 和硬盘驱动器。
引脚分配:连接器 1(Side A 和 Side B)均为内部 HD68(公头)。
参数特性: - UPC 代码:037332096524 - 支持的驱动器数量:4 - 颜色:灰色 - 电缆长度:3.8 英尺(1.16 米,45 英寸) - 运输尺寸:10.00x6.00x3.00 英寸 - 运输重量:0.37 磅(0.17 公斤) - 产品保修期限:有限终身保修
功能详解:该带状电缆可以将多达 4 个内部 SCSI 驱动器/设备连接到内部 SCSI 控制器。
电缆包括主动终结器,UL 额定的扭绞和平铺电缆。
SCSI U160 电缆包括主动终结器,可补偿阻抗不匹配。
应用信息:适用于需要连接多达 5 个驱动器的系统,具有宽 SCSI 控制器卡和带有 HD68 引脚接口的内部 SCSI 驱动器和设备。
封装信息:45 英寸内部 U160 SCSI 带状电缆,5 个带终结器的 HD68M 4 驱动器。
S054-45I 价格&库存
很抱歉,暂时无法提供与“S054-45I”相匹配的价格&库存,您可以联系我们找货
