S404-006
S404-006
    TRIPPLITE
    S404-006
S404-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SCSI Double Shielded Cable (HD68 M/M), 6-ft. MODEL NUMBER: S404-006 Highlights ● Premium double-shielded cable ● 34 twisted-pair conductors System Requirements ● Any external SCSI device or host controller card requiring HD68 interface Package Includes ● Description Multi-platform SCSI III external peripheral cable HD68M/M. This 6ft cable is designed to connect two SCSI III (fast and wide) or SCSI II devices together. Manufactured using double shielded 34 twisted pair high impedance cable. Constructed with low-capacitance, impedance matched, 28 AWG, stranded, tinned copper cable with insulated in polypropylene. Features ● Backwards compatibility with previous SCSI generations ● Double shielded (foil and braid) ● 34 twisted pair conductors ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest Ultra 320 to legacy SCSI-1 and every combination in between Specifications OVERVIEW UPC Code 037332014122 Technology SCSI PHYSICAL Color Beige Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 11.75 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 29.84 x 17.78 x 1.27 1/2 6-ft. SCSI cable HD68M to HD68M double shielded 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 0.86 Shipping Weight (kg) 0.39 CONNECTIONS Side A - Connector 1 HD68 (MALE) Side B - Connector 1 HD68 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
S404-006
物料型号: - 型号编号:S404-006
器件简介: - 该产品为Tripp Lite系列的SCSI双屏蔽电缆(HD68 M/M),长度为6英尺。这是一种多平台SCSI III外部周边电缆HD68M/M,设计用于连接两个SCSI III(快速和宽)或SCSI II设备。使用双屏蔽34对绞线高阻抗电缆制造,构造采用低电容、阻抗匹配、28 AWG、绞合、镀锡铜线,外层绝缘材料为聚丙烯。
引脚分配: - 连接器1(Side A):HD68(公头) - 连接器1(Side B):HD68(公头)
参数特性: - 技术:SCSI - 颜色:米色(Beige) - 电缆长度(英尺):6 - 电缆长度(米):1.83 - 发货尺寸(高宽深/英寸):11.75x7.00x0.50 - 发货尺寸(高宽深/厘米):29.84x17.78x1.27 - 发货重量(磅):0.86 - 发货重量(千克):0.39
功能详解: - 向后兼容以前的SCSI代 - 双屏蔽(箔和编织) - 34对绞线导体 - 所有Tripp Lite SCSI产品,无论SCSI代,均符合ANSI的最新规范,从最新的Ultra 320到传统的SCSI-1以及两者之间的每种组合,Tripp Lite提供完整的内部和外部解决方案,用于SCSI/RAID和光纤通道。
应用信息: - 适用于任何需要HD68接口的外部SCSI设备或主机控制器卡。
封装信息: - UPC代码:037332014122 - 产品保修期限(全球):有限终身保修
S404-006 价格&库存
很抱歉,暂时无法提供与“S404-006”相匹配的价格&库存,您可以联系我们找货
