S366-006
S366-006
    TRIPPLITE
    S366-006
S366-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SCSI Double Shielded Cable (HD50 M/M), 6-ft. MODEL NUMBER: S366-006 Highlights ● Premium double-shielded cable ● 25 twisted-pair conductors System Requirements ● Any external SCSI II device or controller card requiring HD50 interface Package Includes ● Description Multi-platform SCSI II external peripheral cable HD50M/M. This 6ft cable is designed to connect two SCSI II (fast SCSI) devices together. Manufactured using double shielded 25 twisted pair high impedance cable. Constructed with low-capacitance, impedance matched, 28 AWG, stranded, tinned copper cable with insulated in polypropylene. Features ● Backwards compatibility with previous SCSI generations ● Double shielded (foil and braid) ● 25 twisted pair conductors ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI. ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest Ultra 320 to legacy SCSI-1 and every combination in between Specifications OVERVIEW UPC Code 037332014078 PHYSICAL Color Beige Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 0.50 x 5.00 x 8.20 Shipping Dimensions (hwd / cm) 1.27 x 12.70 x 20.83 Shipping Weight (lbs.) 0.70 1/2 6Ft SCSI Cable HD50M to HD50M Double Shielded 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.32 CONNECTIONS Side A - Connector 1 HD50 (MALE) Side B - Connector 1 HD50 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
S366-006
物料型号:S366-006
器件简介:S366-006 是一款 SCSI 二代外部设备连接线,长度为 6 英尺。
它采用优质双屏蔽电缆,拥有 25 对绞线,并设计用于连接两个 SCSI II(快速 SCSI)设备。
引脚分配:HD50 接口,两端都是公头。
参数特性: - 兼容性:向后兼容以前的 SCSI 版本。
- 屏蔽:双屏蔽(箔和编织)。
- 导体:25 对绞线。
- 电缆规格:低电容,阻抗匹配,28 AWG,绞合,镀锡铜线,绝缘材料为聚丙烯。
功能详解:Tripp Lite 的所有 SCSI 产品,无论 SCSI 版本如何,都符合 ANSI 的最新规范,从最新的 Ultra 320 到传统的 SCSI-1,以及两者之间的每种组合。
应用信息:适用于任何需要 HD50 接口的外部 SCSI II 设备或控制卡。
封装信息: - 颜色:米色 - 电缆长度:6 英尺(1.83 米) - 包装尺寸:0.50x5.00x8.20 英寸 - 包装尺寸:1.27x12.70x20.83 厘米 - 运输重量:0.70 磅(0.32 公斤)
产品保修期为有限终身保修。
S366-006 价格&库存
很抱歉,暂时无法提供与“S366-006”相匹配的价格&库存,您可以联系我们找货
