U022-006
U022-006
    TRIPPLITE
    U022-006
U022-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 A to B Cable (M/M), 6 ft. (1.83 m) Highlights ● Meets or Exceeds USB 2.0 Specifications ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices, including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil feature twisted 28AWG data lines, and 24AWG power lines. ● Gold plated connectors provide superior conductivity MODEL NUMBER: U022-006 System Requirements Make the connection between a USB device and your computer's USB port. This USB 2.0 A/B Gold Device Cable assures that you get maximum performance from USB 2.0 devices (e.g. printers, external hard drives). It supports fast data transfer rates of up to 480 Mbps, and is backward compatible with USB 1.1. ● Any USB device requiring a USB cable ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Package Includes ● Features ● USB 2.0 certified ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil ● Gold plated connectors and gold plated copper contacts for superior conductivity. ● Molded connectors and integral strain relief for extra durability and long life. Specifications OVERVIEW UPC Code 037332100016 Technology USB 2.0 (High Speed) Cable Type Passive PHYSICAL Cable Jacket Color Black Wire Gauge (AWG) 28/24 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 1/2 6-ft. USB 2.0 Gold Cable USB-A to USB-B 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.17 Shipping Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U022-006
物料型号: - 型号编号:U022-006
器件简介: - 这是一根6英尺(1.83米)长的USB 2.0 A到B的线缆(公对公),用于连接USB设备和电脑的USB端口。该线缆能够确保从USB 2.0设备(例如打印机、外置硬盘)获得最大性能。支持高达480 Mbps的快速数据传输率,并且向下兼容USB 1.1。
引脚分配: - 端A - 连接器1:USB A(公) - 端B - 连接器1:USB B(公)
参数特性: - 技术:USB 2.0(高速) - 线缆类型:被动 - 物理特性:黑色线缆外皮 - 线规(AWG):28/24 - 线缆长度:6英尺(1.83米) - 发货尺寸:9.00x7.00x0.50英寸 / 22.86x17.78x1.27厘米 - 发货重量:0.15磅 / 0.07千克 - 工作温度范围:14°F至122°F(-10°C至50°C) - 存储温度范围:5°F至140°F(-15°C至60°C) - 工作湿度范围:0%至90% RH,非凝结 - 存储湿度范围:0%至90% RH,非凝结
功能详解: - 符合或超过USB 2.0规范 - 支持低速率和高速率设备(包括多媒体应用)的更快数据传输率(1.5至480 Mbps) - 高级双屏蔽线缆,采用镀锡铜编织和铝箔,具有28AWG数据线和24AWG电源线 - 镀金连接器提供优越的导电性
应用信息: - 任何需要USB线缆的USB设备 - 只有在与USB 2.0设备和USB 2.0控制器一起使用时,才能获得USB 2.0性能
封装信息: - UPC代码:037332100016 - 产品符合RoHS标准 - 提供全球范围内的有限终身保修
U022-006 价格&库存
很抱歉,暂时无法提供与“U022-006”相匹配的价格&库存,您可以联系我们找货
U022-006
  • 1+57.943571+7.48003
