UR024-001
UR024-001
    TRIPPLITE
    UR024-001
UR024-001 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Universal Reversible USB 2.0 Extension Cable (Reversible A to A M/F), 1 ft. (0.31 m) MODEL NUMBER: UR024-001 Highlights ● Universal / Reversible A-Male plugs in any direction ● Extend distances of USB 2.0 cables with this extension cable ● Supports faster data transfer rates (1.5 to 480 Mbps) for low speed and high speed devices, especially multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil feature twisted 28/24 AWG data lines ● Gold plated contacts provide superior conductivity System Requirements ● Any USB device requiring a USB cable ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Reversible Right Angle USB "A" connector plugs in any direction Package Includes Description This 1-ft. (0.31 m) USB extension cable features a Universal / Reversible, A-Male connector, and is manufactured using USB2.0 cable. Universal / Reversible connector allows the cable to be plugged in any direction. This cable is backwards compatible and can also be used with the older USB 1.1 cables. Made with superior foil shielding for reliable error-free data communications. Features nickel plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) makes it perfect for multimedia applications. Features ● 1-ft. (0.31 m), USB 2.0 A-Male to A-Female Extension, with Universal / Reversible "A" Male connector ● USB 2.0 compliant, to 480Mbps transfer rates ● Backward compatible with previous USB generations ● Gold plated contacts and molded ends provide a lifetime of use ● 28AWG Data Pair, 24AWG Power pair Specifications OVERVIEW UPC Code 037332179487 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black 1/2 ● Universal Reversible USB 2.0 AMale to A-Female Extension Cable - 1-ft. (0.31 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 1 Cable Length (m) 0.30 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 USB A (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
UR024-001 价格&库存
很抱歉,暂时无法提供与“UR024-001”相匹配的价格&库存,您可以联系我们找货
