U023-003
U023-003
    TRIPPLITE
    U023-003
U023-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 A to B Cable with Ferrite Chokes (M/M), 3 ft. (0.91 m) MODEL NUMBER: U023-003 Highlights ● Meets or Exceeds USB 2.0 Specifications ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices, including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil and Ferrite chokes, feature twisted 28AWG data lines, and 24AWG power lines. ● Gold plated connectors provide superior conductivity System Requirements ● Any USB device requiring a USB cable with extra shielding capabilities ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Description Tripp Lite's 3-ft. (0.91 m) gold USB2.0 A/B device cable meets or exceeds USB 2.0 specifications. Connects a USB device to a USB port on a computer or hub. Molded in Ferrite Chokes add additional shielding properties for noisy environments. Backward compatible - can be used with older USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free data communications. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) make them perfect for multimedia applications. Features gold plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● USB 2.0 certified ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil, Ferrite chokes ● Gold plated connectors and gold plated copper contacts for superior conductivity. ● Molded connectors and integral strain relief for extra durability and long life. Specifications OVERVIEW UPC Code 037332174253 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black 1/2 Package Includes ● 3-ft. (0.91 m) USB 2.0 Gold Cable USB-A to USB-B with Ferrite Chokes 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 78% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U023-003 价格&库存
很抱歉,暂时无法提供与“U023-003”相匹配的价格&库存,您可以联系我们找货
