U023-006
U023-006
    TRIPPLITE
    U023-006
U023-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 A to B Cable with Ferrite Chokes (M/M), 6 ft. (1.83 m) MODEL NUMBER: U023-006 Highlights ● Meets or Exceeds USB 2.0 Specifications ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices, including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil and Ferrite chokes, feature twisted 28AWG data lines, and 24AWG power lines. ● Gold plated connectors provide superior conductivity System Requirements ● Any USB device requiring a USB cable with extra shielding capabilities ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Features Package Includes ● USB 2.0 certified ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil, Ferrite chokes ● Gold plated connectors and gold plated copper contacts for superior conductivity. ● Molded connectors and integral strain relief for extra durability and long life. Specifications OVERVIEW UPC Code 037332156624 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 1/2 ● 6 ft. USB 2.0 Gold Cable USB-A to USB-B with Ferrite Chokes 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 79% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U023-006
物料型号: - 型号:U023-006
器件简介: - 这是一款USB 2.0 A到B的电缆,带有磁珠,长度为6英尺(1.83米)。它支持高速数据传输,适用于低速和高速设备,包括多媒体应用。
引脚分配: - Side A - 连接器1:USB A(公头) - Side B - 连接器1:USB B(公头)
参数特性: - USB 2.0认证,支持最高480 Mbps的数据传输速率。 - 优质双层屏蔽电缆,带有镀锡铜编织层和铝箔,以及磁珠。 - 镀金连接器提供优越的导电性。 - 直头连接器。
功能详解: - 支持多媒体应用。 - 电缆类型为被动型。 - 电缆外皮颜色为黑色,材料为PVC,并且符合VW-1防火等级。
应用信息: - 适用于需要额外屏蔽能力的USB设备。
封装信息: - 电缆长度:6英尺(1.83米)。 - 包装尺寸和重量:9.00x7.00x0.50英寸(22.86x17.78x1.27厘米),0.20磅(0.09千克)。
U023-006 价格&库存
很抱歉,暂时无法提供与“U023-006”相匹配的价格&库存,您可以联系我们找货
