U024-010
U024-010
    TRIPPLITE
    U024-010
U024-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 Extension Cable (A M/F), 10 ft. (3.05 m) Highlights ● Extend distances of USB 2.0 cables with this extension cable ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices, including multimedia applications ● Premium double-shielded cables with aluminum braid and aluminum mylar foil feature twisted 28/24 AWG data lines ● Gold plated connectors provide superior conductivity MODEL NUMBER: U024-010 System Requirements ● Any device requiring a longer USB cable Package Includes ● Description This 10-ft. (3.05 m) USB gold extension cable is manufactured using USB 2.0 cable. It is designed specifically for use with USB 2.0 A/B device cables. This cable is backwards compatible and can also be used with the older USB 1.1 cables. Made with superior foil shielding for reliable error-free data communications. Features gold plated connectors and gold plated copper contacts for superior conductivity. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) makes it perfect for multimedia applications. the cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● Supports faster data transfer rates (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with aluminum braid and aluminum Mylar foil feature twisted 28/24 AWG data lines ● Gold plated connectors provide superior conductivity ● Extend distances of USB 2.0 cables with this extension cable Specifications OVERVIEW UPC Code 037332116543 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black 1/2 10-ft. (3.05 m) USB 2.0 Gold Extension Cable (USB A M/F) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 86% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U024-010 价格&库存
很抱歉,暂时无法提供与“U024-010”相匹配的价格&库存,您可以联系我们找货
