U026-10M
U026-10M
    TRIPPLITE
    USB 2.0 Cable A Female to A Male 32.8' (10.0m) Shielded
U026-10M 数据手册
USB 2.0 Active Extension Repeater Cable (A M/F), 10M (32.8 ft.) MODEL NUMBER: U026-10M Highlights ● Extends and Boosts the signal to any USB device ● Supports data transfer speeds up to 480Mbps ● Built in Repeater maintains HiSpeed USB signal quality, and electrical / timing specifications ● Plug and Play....Compatible with all major operating systems System Requirements Description ● USB 2.0 enabled computer ( Windows or MAC ) ● The U026-10M provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-004-R) that is connected to the U026-10M. Package Includes Tripp Lite's 10-meter ( 33 ft. ) USB 2.0 active extension cable is a bus powered extension cable that can be used to increase the length of a device cable without the worry of signal loss and potential performance problems. USB limits a cable's length to 16-ft. (4.88 m) Any length above 16-ft. (4.88 m) requires the use of an active cable such as this one. This cable has a signal booster built in. The overall cable length can be extended up to 131-ft. (39.92 m) by daisy chaining up to 4 of these active cables. The cable must be plugged directly into a USB port (either on the PC or a hub). Use a standard 6-ft. (1.83 m), 10-ft. (3.05 m), or 15-ft. (4.57 m) USB A-B cable to reach the desired distance. The U026-10M provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-004-R) that is connected to the U026-10M. Features ● 10 meter ( 33 ft.) USB2.0 Active Extension Cable, USB-A Male to USB-A Female ● Full 480Mbps Transfer rate, as well as backward compatible to USB 1.1 ( 12Mbps ) ● Daisy Chain four cables for a total of 131-ft. (39.92 m) ● Bus Powered...no external power required ● Compatible with all major operating systems....Plug-and-Play; no software to load ● The U026-10M provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-004-R) that is connected to the U026-10M. Specifications OVERVIEW UPC Code 037332173263 Technology USB 2.0 (High Speed) USB Cable Type Active 1/2 ● 10-Meter ( 33 ft. ) USB2.0 A/A Hi-Speed Active Extension / Repeater Cable PHYSICAL Cable Jacket Color Black Cable Length (ft.) 32.8 Cable Length (m) 10.00 Shipping Dimensions (hwd / in.) 2.00 x 5.00 x 6.00 Shipping Dimensions (hwd / cm) 5.08 x 12.70 x 15.24 Shipping Weight (lbs.) 0.76 Shipping Weight (kg) 0.34 ENVIRONMENTAL Operating Temperature Range 28.4 to 125.6 F (-2 to 52 C) Storage Temperature Range -4 to 132.8 F (-20 to 56 C) Relative Humidity 20% to 80% RH, Non-condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U026-10M 价格&库存
很抱歉,暂时无法提供与“U026-10M”相匹配的价格&库存,您可以联系我们找货
