U330-05M
U330-05M
    TRIPPLITE
    U330-05M
U330-05M 数据手册
USB 3.0 SuperSpeed Active Extension Repeater Cable (A M/F), 5M (16.4 ft.) MODEL NUMBER: U330-05M Highlights ● Extend a USB 3.0 signal 16.4-ft. (5 m.) ● Increase the extension distance to 32.8-ft. (10 m.) by connecting two U330-05M together ● Supports USB 3.0 SuperSpeed data transfer rates up to 5Gbps System Requirements Tripp Lite's 16.4-ft. (5 m) USB 3.0 active extension cable is a bus powered extension cable that can be used to increase the length of a device cable without the worry of signal loss and potential performance problems. Increase the extension distance to 32.8-ft. (10 m) by connecting two U330-05M together. USB limits a cable's length to 16-ft. (4.88 m). Any length above 16-ft. (4.88 m) requires the use of an active cable such as this one. This cable has a signal booster built in. The cable must be plugged directly into a USB port (either on the PC or a hub). Use a standard 6-ft. (1.83 m), 10-ft. (3.05 m), or 15-ft. (4.57 m) USB 3.0 A-B cable to reach the desired distance. The U330-05M provides up to 770mA of power to the connected device. If your device requires more than 770mA of power, an external power supply will be required for the connected USB device. Features ● Extend a USB 3.0 signal 16.4-ft. (5 m) ● Increase the extension distance to 32.8-ft. (10 m) by connecting two U330-05M together ● Works together with standard USB 3.0 cables ● Provides up to 770mA of power to the connected device. If your device requires more than 770mA of power, an external power supply will be required for the connected USB device. ● Backward compatible to previous USB generations Specifications OVERVIEW 037332173492 INPUT Bus Powered A USB 3.0 Computer port and USB 3.0 device are required to meet USB 3.0 speeds. A USB 2.0 port or device can be used, but you will be limited to the speeds of that port / device. ● The U330-05M provides up to 770mA of power to the connected device. If your device requires more than 770mA of power, an external power supply will be required for the connected USB device. Package Includes Description UPC Code ● Yes POWER 1/3 ● 16.4-ft. (5 m) USB3.0 Super Speed A/A Active Extension Cable (USB-A M/F) Power Consumption (Watts) 0.25 PHYSICAL Material of Construction ABS, PVC Color Black Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.10 Shipping Weight (lbs.) 0.60 Unit Packaging Type Polybag Unit Weight (lbs.) 0.55 Unit Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range 32 to 158 F (0 to 70 C) Storage Temperature Range 14 to 176 F (-10 to 80 C) Relative Humidity 10% to 90 % RH, Non-Condensing BTUs 0.85 BTU/Hr Power Provided to Connected Device(s) Up to 0.77A CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 USB 3.0 A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty 2/3 © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U330-05M
### 物料型号 - 型号:U330-05M
### 器件简介 - 这是一个USB 3.0主动延伸线缆,用于增加设备线缆的长度,同时避免信号损失和潜在的性能问题。通过连接两个U330-05M,可以将延伸距离增加到32.8英尺(10米)。
### 引脚分配 - Side A - Connector 1:USB 3.0 A(MALE) - Side B - Connector 1:USB 3.0 A(FEMALE)
### 参数特性 - 电源:是 - 输入:USB 3.0 - 连接:Side A - USB 3.0 A(MALE),Side B - USB 3.0 A(FEMALE) - 连接器镀层:镍 - 物理特性:颜色为黑色,材质为ABS, PVC,线缆外皮颜色为黑色,VW-1等级 - 线缆长度:16.4英尺(5.00米) - 发货尺寸:0.50x7.00x9.10英寸 - 发货重量:0.60磅 - 单位包装类型:聚乙烯袋 - 单位重量:0.55磅(0.25公斤) - 环境:操作温度范围32°F至158°F(0°C至70°C),存储温度范围14°F至176°F(-10°C至80°C),相对湿度10%至90%RH,非凝结 - 功率提供给连接设备:高达0.77A
### 功能详解 - 该线缆支持USB 3.0 SuperSpeed数据传输速率,高达5Gbps,并且向下兼容以前的USB版本。 - 无需驱动程序即可使用。 - 提供高达770mA的电源给连接的设备,如果设备需要超过770mA的电源,则需要为连接的USB设备提供外部电源。
### 应用信息 - 适用于需要增加USB设备线缆长度的场景,以避免信号损失和性能问题。
### 封装信息 - 颜色:黑色 - 材质:ABS, PVC - 线缆外皮颜色:黑色 - 线缆长度:16.4英尺(5.00米) - 单位重量:0.55磅(0.25公斤)
U330-05M 价格&库存
很抱歉,暂时无法提供与“U330-05M”相匹配的价格&库存,您可以联系我们找货
