U026-016
U026-016
    TRIPPLITE
    U026-016
U026-016 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 Active Extension Repeater Cable (A M/F), 16 ft. (4.88 m) Highlights ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil feature twisted 28/22 AWG data/power lines ● Gold plated contacts provide superior conductivity for low and high speed devices (1.5 to 480 Mbps.) ● Active extension cable regenerates USB signal for extra-long distances: daisychain up to 80-ft. in most applications MODEL NUMBER: U026-016 System Requirements ● A USB 2.0 port and USB 2.0 device are required to achieve USB 2.0 speeds. A USB 1.1 port and/or device can be used, but you will not be able to achieve USB 2.0 speeds. ● The U026-016 provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-004-R) that is connected to the U026-016. Description Tripp Lite's 16-ft. (4.88 m) USB 2.0 Extension Cable is a bus powered extension cable that can be used to increase the length of a device cable without the worry of signal loss and potential performance problems. USB limits a cable's length to 16-ft. (4.88 m). Any length above 16-ft. (4.88 m) requires the use of an active cable such as this one. This cable has a signal booster built in. The overall cable length can be extended up to 80-ft. (24.38 m) by daisy-chaining up to 5 of these active cables. The U026-016 provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply or need to be plugged into a powered USB 2.0 hub (such as U222-004-R) that is connected to the U026-016. Use a standard 6-ft. (1.83 m), 10-ft. (3.05 m), or 15-ft. (4.57 m) USB cable to reach the desired distance. Features ● Extend a USB 2.0 signal passed the 16-ft. (4.88 m) distance limitation ● Works together with standard USB 2.0 cables ● Bus powered signal booster ● Daisychain up to 5 cables to extend the signal up to 80-ft. (24.38 m) passed the 16-ft. (4.88 m) distance limitation ● The U026-016 provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-004-R) that is connected to the U026-016. Specifications OVERVIEW UPC Code 037332120588 Technology USB 2.0 (High Speed) USB Cable Type Active 1/2 Package Includes ● 16-ft. (4.88 m) USB 2.0 Extension Cable (USB A M/F) 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Black Cable Length (ft.) 16 Cable Length (m) 4.88 Shipping Dimensions (hwd / in.) 1.00 x 4.50 x 5.90 Shipping Dimensions (hwd / cm) 2.54 x 11.43 x 14.99 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 ENVIRONMENTAL Storage Temperature Range -4 to 176 F (-20 to 80 C) Operating Temperature -20 to 80 C (-4 to 176 F) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U026-016 价格&库存
很抱歉,暂时无法提供与“U026-016”相匹配的价格&库存,您可以联系我们找货
U026-016
  • 1+308.630471+39.76218
