U030-003
U030-003
    TRIPPLITE
    USB 2.0 A M TO 5PIN MINI-B M 3'
U030-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 A to Mini-B Cable (A to 5Pin Mini-B, M/M), 3 ft. (0.91 m) MODEL NUMBER: U030-003 Highlights ● Meets or Exceeds USB 2.0 Specifications ● Connects to Cameras, PDA's, etc with Mini-B 5-Pin connectors System Requirements Description Tripp Lite's 3-ft. (0.91 m) gold USB 2.0 A /Mini-B 5-pin device cable Meets or Exceeds USB 2.0 Specifications. Connects a Digital camera, PDA, Cell Phone, etc to a USB port on a computer or hub. Backward compatible - can be used with older USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free data communications. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) make them perfect for multimedia applications. Features gold plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● Meets or Exceeds USB 2.0 Specifications ● Connects to Cameras, Cell Phones, PDA's, etc with 5-Pin Mini-B USB connectors ● Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including multimedia applications ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil ● Gold plated connectors and gold plated copper contacts for superior conductivity. ● Molded connectors and integral strain relief for extra durability and long life. Specifications OVERVIEW UPC Code 037332160539 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL 1/2 ● Any USB device requiring a USB cable with Mini-B 5-Pin connector ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Black Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.08 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB MINI-B 5-PIN (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U030-003
物料型号: - 型号编号:U030-003
器件简介: - 这款USB 2.0 A到Mini-B 5Pin设备线缆满足或超过USB 2.0规范。适用于连接数字相机、PDA、智能手机或其他兼容设备到电脑或集线器的USB端口。同时向后兼容旧版USB 1.1应用。USB 2.0线缆包含优越的箔屏蔽,以确保可靠、无误的数据通信。USB 2.0显著更快的数据传输速率(高达480 Mbps),非常适合多媒体应用。产品特点包括镀金连接器和镀金铜接触点,以提供卓越的导电性。线缆采用模塑连接器和整体应力消除设计,以增强耐用性和延长使用寿命。
引脚分配: - Side A - 连接器1:USB A(公头) - Side B - 连接器1:USB Mini-B 5-Pin(公头)
参数特性: - 技术:USB 2.0(高速) - 线缆类型:被动 - 物理特性: - 线缆颜色:黑色 - 线缆长度(英尺):3 - 线缆长度(米):0.91 - 环境特性: - 工作温度范围:14°F至122°F(-10°C至50°C) - 存储温度范围:5°F至140°F(-15°C至60°C) - 工作湿度范围:0%至90% RH,非凝结 - 存储湿度范围:0%至90% RH,非凝结 - 标准与合规性: - 产品合规性:RoHS
功能详解: - 满足或超过USB 2.0规范 - 连接到带有5-Pin Mini-B USB连接器的相机、手机、PDA等 - 支持更快的数据传输速率(1.5至480 Mbps),适用于低速和高速设备,包括多媒体应用 - 高级双屏蔽电缆,带有镀锡铜编织和铝箔 - 镀金连接器和镀金铜接触点,以提供卓越的导电性 - 模塑连接器和整体应力消除,以增强耐用性和延长使用寿命
应用信息: - 适用于任何需要带有Mini-B 5-Pin连接器的USB线缆的USB设备
封装信息: - UPC代码:037332160539 - 发货尺寸(高宽深/英寸):9.00x7.00x0.50 - 发货尺寸(高宽深/厘米):22.86x17.78x1.27 - 发货重量(磅):0.08 - 发货重量(千克):0.04
U030-003 价格&库存
很抱歉,暂时无法提供与“U030-003”相匹配的价格&库存,您可以联系我们找货
U030-003
  • 1+45.728281+5.91565
  • 10+38.8220710+5.02223
  • 25+36.3862225+4.70712
  • 50+34.6471850+4.48214
  • 100+32.99374100+4.26825
  • 250+30.92764250+4.00097
  • 500+29.45209500+3.81008
  • 1000+28.047311000+3.62835
  • 2500+26.293372500+3.40145
库存:1765
