Panel Mount USB Cable - A Male to A Female
PRODUCT ID: 908
DESCRIPTION
This handy USB extension cable will make it easy for you to enclose a device that
has a A type (USB host) port. We think this would be most handy when putting a
Beagle Bone, Raspberry Pi or Mintyboost into a box.
The jack half has two mounting 'ears' with 4-40 screws installed, 30mm apart. The
ears are flexible so the holes don't have to drilled very precisely. Can be used with
box walls up to 0.25" wide. The screws can be put on from the back for 'reverse'
mounting if the box thickness is a problem. Entire unit is 13.4" long from tip to tip
(with 10.2" cabling between USB connectors).
https://www.adafruit.com/product/908
1/27/2016
Technical Details
Panel mount USB type A socket with USB type A plug at cable end
28 AWG data, 24 AWG power wires
Shielded with wire braid
As of May 9th, 2014 the dimensions are:
13.4" / 340mm long from tip to tip
10.2" / 259 mm cable length between USB connectors
Two 10mm 4-40 mounting screws, 30mm apart
Weight: 27g
很抱歉,暂时无法提供与“908”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.628401+4.49420
