U050-010
U050-010
    TRIPPLITE
    U050-010
U050-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 A to Micro-B Cable (M/M), 10 ft. (3.05 m) Highlights ● Next Generation USB Digital Device Connector ● Provides both Data and Power transfers ● USB 2.0 480Mbps Transfer rates ● Standard "A" Male to Micro-B Male MODEL NUMBER: U050-010 System Requirements ● Digital devices that use the USB Micro-B Female socket Package Includes ● Features ● USB A Male to Micro-B Male ● Available in 3-ft. (0.91 m), 6-ft. (1.83 m), and 10-ft. (3.05 m) lengths ● 480Mbps USB 2.0 Data Transfer Rates ● Data and Power transference Specifications OVERVIEW UPC Code 037332160508 Technology USB 2.0 (High Speed) Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.17 Shipping Weight (kg) 0.08 ENVIRONMENTAL 1/2 10-ft. (3.05 m) USB 2.0 A-Male to Micro-B Male 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U050-010
物料型号为U050-010,是Tripplite品牌的USB 2.0 A到Micro-B电缆(公对公),长度为10英尺(3.05米)。
该电缆支持数据和电源传输,具有480Mbps的传输速率,符合USB 2.0标准。
系统要求为使用USB Micro-B母座的数字设备。
产品包装包括一根10英尺(3.05米)的USB 2.0 A公到Micro-B公电缆。
引脚分配为: - Side A - 连接器1:USB A(公) - Side B - 连接器1:Micro-USB B(公)
参数特性包括: - 技术:USB 2.0(高速) - 电缆类型:被动 - 物理特性:黑色电缆外皮,电缆长度10英尺(3.05米) - 运输尺寸:9.00 x 7.00 x 0.50英寸(22.86 x 17.78 x 1.27厘米) - 运输重量:0.17磅(0.08千克) - 工作温度范围:14°F至122°F(-10°C至50°C) - 存储温度范围:5°F至140°F(-15°C至60°C) - 工作湿度范围:0%至90% RH,非凝结 - 存储湿度范围:0%至90% RH,非凝结 - 产品合规性:符合RoHS标准 - 产品保修期:全球范围内的有限终身保修
封装信息为黑色直头连接器,电缆长度为10英尺(3.05米)。
产品符合RoHS标准,提供有限的终身保修。
U050-010 价格&库存
很抱歉,暂时无法提供与“U050-010”相匹配的价格&库存,您可以联系我们找货
U050-010
  • 1+87.306951+11.33638
