USB 2.0 Adapter Cable - USB-C to USB Micro-B
(M/F), 6-in. (15.24 cm)
Highlights
Connect devices with a USB
Micro-B port to the USB Type-C
(USB-C) port on your tablet,
laptop, ultrabook or computers
USB Type-C connector is
reversible, so there is no
guessing on which way to plug it
in
MODEL NUMBER: U040-06N-MIC-F
System Requirements
A device with a Micro-B
connector
A tablet, laptop, ultrabook or
computer with an available USB
Type-C (USB-C) port
Package Includes
Convert the USB Type-C (USB-C) port on your device, tablet, laptop, ultrabook, or computer to a USB
Micro-B Female port
Features
6-in. USB Type-C (USB-C) Male to USB Micro-B Female adapter cable
Converts the USB Type-C port on your tablet, laptop, ultrabook, or computer to a USB Micro-B port,
allowing for Micro-B devices to sync and charge
USB Type-C connector is reversible, so there is no guessing on which way to plug it in
Supports USB 2.0 data transfer rates up to 480Mbps
Backward compatible with previous USB generations
Gold plated contacts and molded ends provide a lifetime of use
30AWG Data Pair / 24AWG Power Pair
Specifications
OVERVIEW
UPC Code
037332189226
Technology
USB 2.0 (High Speed)
USB Cable Type
Passive
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
Black
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
3.0MM
1/2
USB 2.0 Hi-Speed Adapter
Cable, USB Type-C (USB-C)
Male to USB Micro-B Female, 6in.
Cable Length (ft.)
0.5
Cable Length (m)
0.15
Cable Length (in.)
6
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.04
Shipping Weight (kg)
0.02
ENVIRONMENTAL
Operating Temperature Range
14 to 140 F (-10 to 60 C)
Storage Temperature Range
-4 to 185 F (-20 to 85 C)
Relative Humidity
10% to 85%, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
MICRO-USB B (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U040-06N-MIC-F”相匹配的价格&库存,您可以联系我们找货
