U038-006
U038-006
    TRIPPLITE
    USB2.0A-MTOC-MCABLE6'
U038-006 数据手册
USB-A to USB-C Cable, USB 2.0, (M/M), 6 ft. (1.83 m) MODEL NUMBER: U038-006 Highlights ● 6-ft. USB 2.0 A to USB Type-C (USB-C) device cable ● USB Type-C connector is reversible, so there is no guessing on which way to plug it in System Requirements ● A device with a USB Type-C (USB-C) connector ● A USB charger, or a laptop, ultrabook or computer with an available USB A port Package Includes ● Connect devices with a USB Type-C (USB-C) connector to a USB charger, or the USB port on your laptop, ultrabook or computer Features ● 6-ft. USB 2.0 A to USB Type-C (USB-C) device cable ● Connect devices with a USB Type-C connector to a USB charger, or the USB port on your laptop, ultrabook or computer ● USB Type-C connector is reversible, so there is no guessing on which way to plug it in.....it connects in either direction! ● Supports USB 2.0 data transfer rates up to 480Mbps ● Backward compatible with previous USB generations ● Gold plated contacts and molded ends provide a lifetime of use ● 28AWG Data Pair / 22AWG Power pair Specifications OVERVIEW UPC Code 037332188571 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 1/2 USB 2.0 A Male to USB Type-C (USB-C) Male Device Cable - 6ft Cable Outer Diameter (OD) 3.5MM Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 14 to 140 F (-10 to 60 C) Storage Temperature Range -4 to 185 F (-20 to 85 C) Relative Humidity 10% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U038-006 价格&库存
很抱歉,暂时无法提供与“U038-006”相匹配的价格&库存,您可以联系我们找货
