Panel Mount USB Cable - B Female to Mini-B
Male
PRODUCT ID: 936
DESCRIPTION
This handy USB extension cable will make it easy for you to enclose a device that
has a mini-B USB type port. We think this would be most handy when putting a
Teensy, FTDI friend, USB LiPo charger, USB Boarduino, etc into a box!
The jack half has two mounting 'ears' with M3 screws installed, ~28.5mm apart.
Can be used with box walls 0.125" to 0.25" wide. If you have a thinner-walled box,
simply swap out the M3 screws for shorter ones. Entire cable is 12.5"/318mm long.
https://www.adafruit.com/product/936
1/27/2016
Technical Details
Cable length: 12.5" (318mm)
Screw size: 12mm, M3
很抱歉,暂时无法提供与“936”相匹配的价格&库存,您可以联系我们找货
