N820-35M
N820-35M
    TRIPPLITE
    N820-35M
N820-35M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable, (LC/LC) - Aqua, 35M (115 ft.) MODEL NUMBER: N820-35M Highlights ● Designed for 10-Gig Ethernet applications...OM3 Rated ● Backward compatible with existing 50/125 fiber ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket Package Includes ● Features ● 35M (114.82-ft.) LC/LC, OM3 Rated ● 10gb Ethernet speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332165121 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White Cable Jacket Material LSZH 1/3 35M (114.82-ft.) Duplex Multimode 50/125 Aqua OM3 Fiber Patch Cable, LC/LC 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 114.8 Cable Length (m) 35.00 Cable Length (in.) 1378 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Shipping Dimensions (hwd / in.) 12.00 x 10.50 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 26.67 x 1.27 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 Fiber Cable Length 35M (114.8 ft) ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0 dB/km Insertion Loss 0.20 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-35M
物料型号:N820-35M
器件简介:这是一根35米(114.82英尺)长的双工多模50/125 OM3光纤跳线,LC/LC接口,符合IEEE 802.3ae和TIA LOMMF标准,适用于10Gb以太网,支持最高300米@850nm的传输距离。
引脚分配:连接器1在A端和B端均为LC双工(公头)。
参数特性: - 光纤类型:多模OM3 - 连接器颜色:白色 - 护套颜色:水蓝色 - 护套材料:LSZH(低烟无卤) - 护套等级:OFNR - 包层直径:125微米 - 核心直径:50微米 - 光纤数量:2 - 光纤长度:35米(114.8英尺) - 最小弯曲半径:20毫米(动态);10毫米(静态) - 工作温度范围:-20°C至60°C - 存储温度范围:-20°C至60°C - 工作湿度范围:5%至85% RH,非凝结 - 存储湿度范围:35%至65% RH,非凝结 - 网络兼容性:1 Gbps、10 Gbps、25 Gbps、40 Gbps、100 Gbps - 衰减@850nm:3.0 dB/km - 插入损耗:0.20 dB
功能详解:该光纤跳线支持10Gb以太网速度,与VCSEL和LED激光光源兼容,具有高速、高带宽、低成本的特点,并且与旧版局域网兼容,非常适合光纤通道(SAN)应用。
应用信息:适用于需要高速数据传输和网络升级的场合,如数据中心、企业网络和存储区域网络。
封装信息:产品采用水蓝色低烟无卤护套,白色LC双工连接器,长度为35米,符合环保和安全标准。
N820-35M 价格&库存
很抱歉,暂时无法提供与“N820-35M”相匹配的价格&库存,您可以联系我们找货
