N844-LOOP-12F
N844-LOOP-12F
    TRIPPLITE
    PATCH CABLE FIBER
N844-LOOP-12F 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States MTP / MPO Fiber Optic Loopback Tester (Multimode 50/125um, OM3) - Female MODEL NUMBER: N844-LOOP-12F Highlights ● MTP / MPO Loopback for 40GbE QSFP+ Optical Testing ● 50/125 OM3 6-Fiber System Requirements ● Networking hardware with MTP / MPO ports Package Includes ● Description Tripp Lite N844-LOOP-12F MTP / MPO OM3 Fiber Optic Loopback Tester is typically used for test and measurement procedures in networking environments.The device is ideal for a multitude of applications that require signal looping in a MTP / MPO form factor. Features push-pull tab for easy disconnect. A dust cap is included for protection during storage. Features ● MTP / MPO OM3 Loopback Tester ● Push-pull tab for quick disconnect ● Protective dust cover included for protection during storage ● 4-inch overall length ● Pin config: 1 -12, 2-11, 3-10, 4-9, 5-8, 6-7 Specifications OVERVIEW UPC Code 037332188205 Accessory Type Cable Tester Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color Aqua; Black 1/3 MTP / MPO Fiber Optic Loopback Tester (Multimode 50/125um, OM3) - Female 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 12 Cable Length (ft.) 0.33 Cable Length (m) 0.10 Cable Length (in.) 4 Cable Length (cm) 10.16 Minimum Bend Radius 20mm (Dynamic); 10mm (Static) Shipping Dimensions (hwd / in.) 5.90 x 4.00 x 0.50 Shipping Dimensions (hwd / cm) 14.99 x 10.16 x 1.27 Shipping Weight (lbs.) 0.01 Shipping Weight (kg) 0.01 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0 dB / km Insertion Loss 0.35 dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 12-STRAND MTP/MPO (FEMALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N844-LOOP-12F 价格&库存
很抱歉,暂时无法提供与“N844-LOOP-12F”相匹配的价格&库存,您可以联系我们找货
