N424-01M
N424-01M
    TRIPPLITE
    FIBER COND PATCH CABLE SC/LC 3FT
N424-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Fiber Optic Mode Conditioning Patch Cable (SC/LC), 1M (3 ft.) MODEL NUMBER: N424-01M Highlights ● Converts Singelemode SC GBIC to Multimode LC Patch Panel ● 62.5/125 and 9/125 ● Run 1000Base-LX Gigabit Ethernet over MMF by offsetting signal loss Package Includes ● Features ● Use SC GBIC Singlemode Transceivers on Multimode Fiber Backbones with LC patch bays ● 62.5/125 and 9/125 ● Offsets the Singlemode Laser launch from the center of a Multimode fiber ● Available in a variety of connector combinations Specifications OVERVIEW UPC Code 037332131645 Optical Mode OM1 PHYSICAL Cable Jacket Color Orange; Yellow Connector Color Blue; Gray; Black Cable Jacket Material PVC Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 3.3 1/3 SC / Mode Conditioning to LC Fiber Optic Patch Cable, 1M ( 3ft. ) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20 mm (Dynamic); 10 mm (Static) Shipping Dimensions (hwd / in.) 0.25 x 5.00 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 12.70 x 17.78 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Attenuation @ 850NM 3.0 dB/km Insertion Loss MM to MM 0.20 dB; MM to SM 0.30 dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N424-01M 价格&库存
很抱歉,暂时无法提供与“N424-01M”相匹配的价格&库存,您可以联系我们找货
