CAB.628
CAB.628
    TAOGLASLIMITED
    CAB.628
CAB.628 数据手册
Specification Part No. : CAB.628 Description : Taoglas Cable Assembly IPEX MHFI to RP-SMA(F)Bulkhead Straight Connector with 95mm 1.13 cable SPE-12-8-152/E/WY Page 1 of 6 1. Cable Insertion Loss 2. 1.13 Cable Specification 2.1 Drawing – Cross Section SPE-12-8-152/E/WY Page 2 of 6 2.2 Structure and Dimensions 2.3 Electrical & Physical Specification 1 2 Item: Rating Temp Voltage: 32 AWG 105°C 30V UL 1979 3 Insulation Resistance: 1000 MEGA OHM-KM Min. 4 Conductor Resistance: 545 OHM/KM/20°C Max. 5 Dielectric Strength: AC 1.0 KV/minute 6 Spark test: 2.5 KV 7 Insulation Unaged Aged 8 Jacket Unaged Aged Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) 9 Nom. Impedance 50  3 Ohms 10 Nom. Capacitance 96  3 pF/m 11 Nom. Vel. Of Prop. 69% 12 VSWR (0-6GHz) Max 1.3 13 Flame Test VW-1 OK 14 Attenuation (dB/1M) 2.0GHz 2.80 2.4GHz 3.10 3.0GHz 3.50 4.0GHz 4.00 5.0GHz 4.60 6.0GHz 5.10 SPE-12-8-152/E/WY Page 3 of 6 3. Technical Drawing 3.1 CAB.628 SPE-12-8-152/E/WY Page 4 of 6 3.2 Recommended Mounting Hole – SMA(F) Bulkhead SPE-12-8-152/E/WY Page 5 of 6 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-152/E/WY Page 6 of 6
CAB.628
根据检索结果,PDF文档中的物料型号为CAB.628,描述为Taoglas Cable Assembly IPEX MHFI到RP-SMA(F)直通式壁板连接器,带有95mm直径的1.13电缆。
以下是关于该物料的详细信息:
1. 器件简介:文档提供了Taoglas CAB.628型号的电缆组件的规格说明。
2. 引脚分配:文档没有明确提供引脚分配图,但提供了技术图纸,包括RP-SMA(F)BK ST和IPEX MHFI接口的详细信息。
3. 参数特性: - 额定温度电压:105°C,30V,符合UL1979标准。
- 绝缘电阻:最小1000兆欧-公里。
- 导体电阻:最大545欧姆/公里/20°C。
- 介电强度:交流1.0千伏/分钟。
- 火花测试:2.5千伏。
- 阻抗:50±3欧姆。
- 电容:96±3皮法/米。
- 传播速度:69%。
- VSWR(0-6GHz):最大1.3。
- 火焰测试:VW-1OK。
- 衰减(dB/1M):在不同频率下有不同的值,例如在2.0GHz时为2.80dB,在6.0GHz时为5.10dB。
4. 功能详解:文档提供了电缆组件的电气和物理规格,包括结构、尺寸、材料和性能测试。
5. 应用信息:文档没有明确提供应用信息,但根据组件的规格,它适用于需要高性能射频连接的应用。
6. 封装信息:文档提供了组件的推荐安装孔尺寸和材料清单。
请注意,文档中还包含了Taoglas的版权声明和免责声明。
CAB.628 价格&库存
很抱歉,暂时无法提供与“CAB.628”相匹配的价格&库存,您可以联系我们找货
CAB.628
    CAB.628
    • 25+22.71900
    • 100+18.63224
    库存:76
    CAB.628
      • 19+41.8938519+5.42400
      • 95+37.7044795+4.88160
      库存:76
