CAB.A02
CAB.A02
    TAOGLASLIMITED
    CAB.A02
CAB.A02 数据手册
CAB.A02 Description: SMA(F) Bulkhead Straight Jack to 95mm of Ø0.81mm IPEX MHFIII (W.FL Compatible) Features: Cable Assembly SMA(F) Bulkhead Straight Jack IPEX MHFIII (W.FL Compatible) 95mm Ø0.81mm cable RoHS & Reach Compliant SPE-11-8-118-D 1. Introduction 3 2. Cable Specifications – RG-178 4 3. Cable Insertion Loss 6 4. Mechanical Drawing 7 5. Packaging 8 Changelog 9 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-11-8-118-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction CAB.A02 is a 95mm Ø0.81mm cable assembly with IPEX MHFIII (W.FL Compatible) and SMA Female 1.The Taoglas Introduction Bulkhead Jack connectors. Taoglas provides customized length and connector variants subject to MOQ. Contact your regional Taoglas customer support team for details. 1. Introduction 1. Introduction 1. Introduction SPE-11-8-118-D www.taoglas.com 3 2. Cable Specifications – RG-178 Cross Section 3. 2.1Antenna Characteristics2. Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. Specifications 3. Antenna Characteristics2. 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 2.2 Cross Section Specifications Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-118-D Specifications www.taoglas.com 4 2.3 1 2 3 4 5 6 7 8 Cross Section Rating Temp Voltage: Insulation Resistance: Conductor Resistance: Dielectric Strength: Spark test: Nom. Impedance Nom. Capacitance Standard Attenuation: SPE-11-8-118-D -40°C to 85°C 1000 MEGA OHM-KM Min. 1400 OHM/KM/20°C Max. AC 1.0 KV/minute 2.5 KV 50 ± 3 Ohms 97 ± 3 pF/m 1GHz 3.6 2GHz 5.1 3GHz 6.2 4GHz 7.5 5GHz 8.5 6GHz 9.4 www.taoglas.com 5 3. Cable Insertion Loss 4. Antenna Radiation Patterns3.Antenna CAB.A02 Characteristics 0 S21 -5 4. Antenna Radiation Patterns S21(dB) -10 -15 4. Antenna Radiation Patterns3.Antenna -20 Characteristics -25 -30 4. 0 1000 2000 3000 4000 5000 Antenna Radiation Patterns3. Antenna 6000 7000 8000 Freq(MHz) Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-11-8-118-D www.taoglas.com 6 4. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-11-8-118-D Mechanical Drawing www.taoglas.com 7 5. Packaging 4. 6. 100pcsPackaging5. CAB.A02 per PE Bag Mechanical Drawing 6. 150mm Bag Dimension: 260*150mm Weight: 410g Packaging 260mm 7. Application Note6. Packaging5. Mechanical Drawing 6. 2000pcs Packaging5. CAB.A02 per Carton Mechanical Drawing Dimensions: 360*310*160mm Weight: 8.5Kg 6. 160mm Packaging 360mm 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. 310mm Mechanical Drawing 6. Packaging5. SPE-11-8-118-D Mechanical Drawing www.taoglas.com 8 Changelog for the datasheet SPE-11-8-118 – CAB.A02 Revision: D Date: Notes: 2020-02-13 Author: Jack Conroy Previous Revisions Revision: C Date: Notes: 2015-08-04 Added Hole Data Author: Jack Conroy Date: Notes: 2011-10-20 Author: Aine Doyle Revision: B Revision: A (Original First Release) Date: Notes: Author: SPE-11-8-118-D 2011-10-14 Initial Release Aine Doyle www.taoglas.com 9 www.taoglas.com © Taoglas SPE-11-8-118-D www.taoglas.com 10
CAB.A02 价格&库存
很抱歉,暂时无法提供与“CAB.A02”相匹配的价格&库存,您可以联系我们找货
CAB.A02
    • 20+45.80072
    • 63+43.60016
    • 250+41.67769
    • 624+39.85195
    • 1871+38.20757
    库存:93
