CAB.719
CAB.719
    TAOGLASLIMITED
    CAB.719
CAB.719 数据手册
SPECIFICATION Part No. : CAB.719 Product Name : Taoglas Cable Assembly Hirose U.FL to SMA(F)Bulkhead Straight Connector with 100mm 1.13 cable Photo : SPE-12-8-101/B/WY Page 1 of 5 1. Cable Insertion Loss 2. 1.13 Cable Specification 2.1 Drawing – Cross Section SPE-12-8-101/B/WY Page 2 of 5 2.2 Structure and Dimensions 2.3 Electrical & Physical Specification 1 2 Item: Rating Temp Voltage: 32 AWG 105°C 30V UL 1979 3 Insulation Resistance: 1000 MEGA OHM-KM Min. 4 Conductor Resistance: 545 OHM/KM/20°C Max. 5 Dielectric Strength: AC 1.0 KV/minute 6 Spark test: 7 Insulation 2.5 KV Unaged Aged 8 Jacket Unaged Aged Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) 9 Nom. Impedance 50  3 Ohms 10 Nom. Capacitance 96  3 pF/m 11 Nom. Vel. Of Prop. 69% 12 VSWR (0-6GHz) Max 1.3 13 Flame Test VW-1 OK 14 Attenuation (dB/1M) 2.0GHz 2.80 2.4GHz 3.10 3.0GHz 3.50 4.0GHz 4.00 5.0GHz 4.60 6.0GHz 5.10 SPE-12-8-101/B/WY Page 3 of 5 3. Technical Drawing 3.1 CAB.719 SPE-12-8-101/B/WY Page 4 of 5 3.2 Connectors 3.3 Recommended Mounting Hole – SMA(F) Bulkhead SPE-12-8-101/B/WY Page 5 of 5
CAB.719 价格&库存
很抱歉,暂时无法提供与“CAB.719”相匹配的价格&库存,您可以联系我们找货
CAB.719
    CAB.719
      CAB.719
      • 15+29.24814
      • 90+24.98001
      • 100+20.28871
      库存:98
