CAB.0101
CAB.0101
    TAOGLASLIMITED
    CAB.0101
CAB.0101 数据手册
CAB.0101 Description: SMA(F) O-Ring to 100mm RG-174 SMB(F)Plug Features: Taoglas Cable Assembly SMA(F)Bulkhead Straight SMB(F) Plug 100mm RG-174 cable RoHS & Reach Compliant SPE-11-8-072/E 1. Introduction 3 2. RG-174 Specifications 4 3. Mechanical Drawing 6 Changelog 7 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-072/E www.taoglas.com 2 1. Cable Insertion Loss 3. Antenna Characteristics2. Specifications CAB.0101 S21 0 3. Antenna Characteristics -5 4. S21(dB) -10 Antenna Radiation Patterns3.Antenna -15 Characteristics2. -20 Specifications -25 3. Antenna Characteristics2. -30 0 1000 2000 3000 Specifications 4000 5000 6000 7000 8000 Freq(MHz) 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-072/E Specifications www.taoglas.com 3 2. RG-174 Cable Specification 2.1 4. Drawing – Cross Section Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 2.2 4. Structure and Dimensions Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-11-8-072/E www.taoglas.com 4 2.3 Electrical & Physical Specification 1 2 3 4 5 6 7 Temperature rating: Voltage Rating: Insulation Resistance: Conductor Resistance: Capacitance: Dielectric Strength Impedance: 8 Standard Attenuation: SPE-11-8-072/E 80°C 30V 10MΩ-Km (Min) at 20°C dc 500V(EIA-364-21) 20°C 26 AWG: 148.96 Ω/Km (Max) 30.8pf/ft AC 500V/1 minute no breakdown (EIA-364-20) 10MHz3GHz 50  5 Ω 100MHz 8.4 dB/100ft 200MHz 12.5 dB/100ft 400MHz 19.0 dB/100ft 900MHz 31.0 dB/100ft 1GHz 34.0 dB/100ft 1.8GHz 49.4 dB/100ft 2.34GHz 53.0 dB/100ft www.taoglas.com 5 3. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-11-8-072/E Mechanical Drawing www.taoglas.com 6 Changelog for the datasheet SPE-11-8-072 – CAB.0101 Revision: E (Current Version) Date: Changes: Changes Made by: 2019-03-13 Updated the drawing Jack Conroy Previous Revisions Revision: D Date: Changes: Changes Made by: 2015-08-04 Added Mounting Hole Aine Doyle Revision: C Date: Changes: Changes Made by: 2011-10-19 Taoglas Revision: B Date: Changes: Changes Made by: 2011-09-05 Packaging Details Updated Taoglas Revision: A (Original First Release) Date: Notes: Author: SPE-11-8-072/E 2011-08-10 Taoglas www.taoglas.com 7 www.taoglas.com SPE-11-8-072/E www.taoglas.com 8
CAB.0101 价格&库存
很抱歉,暂时无法提供与“CAB.0101”相匹配的价格&库存,您可以联系我们找货
