CAB.954
CAB.954
    TAOGLASLIMITED
    CAB.954
CAB.954 数据手册
SPECIFICATION Part No. : CAB.954 Product Name : Taoglas Cable Assembly N Type Jack with O-Ring to 300mm(11.81”) 1.37 to IPEX MHFI(U.FL comp) Photo : SPE-13-8-081/B/WY Page 1 of 6 1. Cable Insertion Loss SPE-13-8-081/B/WY Page 2 of 6 2. 1.37 Cable Specification 2.1 Drawing – Cross Section 2.2 Structure and Dimensions  Material – Silver Coated Copper  Material – FEP  Material–Tinned-Coated Copper  Material – FEP  Avg. Thickness- 0.30mm  Structure –  Avg. Thickness- 0.13mm  30AWG(7/0.102mm)  Diameter – 0.92  0.03mm  Diameter - 0.31mm  Color - Clear 16/6/0.050mm±0.003  Coverage – 95%  Diameter – 1.37  0.05mm  Color – Grey GY-08/Black  Diameter – 1.15  0.05mm  SPE-13-8-081/B/WY Page 3 of 6 2.3 Electrical & Physical Specification 1 2 Item: Rating Temp Voltage: 30 AWG 105°C 30V UL 1979 3 Insulation Resistance: 3000 MEGA OHM-KM Min. 4 Conductor Resistance: 335 OHM/KM/20°C Max. 5 Dielectric Strength: AC 1.0 KV/minute 6 Spark test: 7 Insulation 8 Jacket 2.5 KV Unaged Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Aged Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) Unaged Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Aged Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) 9 Nom. Impedance 50  3 Ohms 10 Nom. Capacitance 96  3 pF/m 11 Nom. Vel. Of Prop. 69% 12 VSWR (0-6GHz) Max 1.3 13 Flame Test VW-1 OK 14 Thermal Shock Less 1mm at 232C/1 HR 13 Bend Radius 9mm min. 14 Attenuation (dB/1M) 2.0GHz 2.20 2.4GHz 2.60 3.0GHz 2.80 4.0GHz 3.40 5.0GHz 3.80 6.0GHz 4.30 SPE-13-8-081/B/WY Page 4 of 6 3. Technical Drawing 3.1 CAB.954 SPE-13-8-081/B/WY Page 5 of 6 3.2 Connectors SPE-13-8-081/B/WY Page 6 of 6
CAB.954 价格&库存
很抱歉,暂时无法提供与“CAB.954”相匹配的价格&库存,您可以联系我们找货
