CAB.695
CAB.695
    TAOGLASLIMITED
    CAB.695
CAB.695 数据手册
SPECIFICATION Part No. : CAB.695 Product Name : Taoglas Cable Assembly IPEX MHFI to FME Bulkhead Straight Jack RG-178 100mm DC-200MHz Photo : SPE-13-8-084/A/WY Page 1 of 5 1. Cable Insertion Loss (Note: FME connector operation frequency range:DC-200MHz) 2. RG-178 Cable Specification 2.1 Drawing – Cross Section SPE-13-8-084/A/WY Page 2 of 5 2.2 Structure and Dimensions 2.3 Electrical & Physical Specification 1 2 Item: Rating Temp Voltage: 30 AWG 105°C 30V UL 1979 3 Insulation Resistance: 3000 MEGA OHM-KM Min. 4 Conductor Resistance: 838 OHM/KM/20°C Max. 5 Dielectric Strength: AC 1.0 KV/minute 6 Spark test: 7 Insulation 8 Jacket 2.5 KV Unaged Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Aged Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) Unaged Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Aged Tensile Strength Unaged Min 75%(168HRS*232°C) Elongation Unaged Min 75%(168HRS*232°C) 9 Nom. Impedance 50  3 Ohms 10 Nom. Capacitance 95.8  3 pF/m 11 Nom. Vel. Of Prop. 69.5% 12 VSWR (0-6GHz) Max 1.3 13 Attenuation (dB/1M) 1.0GHz 1.70 2.0GHz 2.50 3.0GHz 3.20 4.0GHz 3.60 5.0GHz 3.95 6.0GHz 4.80 SPE-13-8-084/A/WY Page 3 of 5 3. Technical Drawing 3.1 CAB.695 SPE-13-8-084/A/WY Page 4 of 5 3.2 Connectors SPE-13-8-084/A/WY Page 5 of 5
CAB.695 价格&库存
很抱歉,暂时无法提供与“CAB.695”相匹配的价格&库存,您可以联系我们找货
CAB.695
    • 100+32.04116
    库存:11
