SPECIFICATION
Part No.
CAB.616
Product Name
Taoglas Cable Assembly
IPEX MHFI to SMA(F)Bulkhead Straight with O-Ring Connector
with 100mm 1.37 cable
SPE-15-8-042/B/WY
Page 1 of 6
1.
Cable Insertion Loss
2.
1.37 Cable Specification
2.1 Drawing – Cross Section
SPE-15-8-042/B/WY
Page 2 of 6
2.2 Structure and Dimensions
Material – Silver Coated
Copper
Material – FEP
Material–Tinned-Coated Copper
Material – FEP
Avg. Thickness- 0.30mm
Structure –
Avg. Thickness- 0.13mm
30AWG(7/0.102mm)
Diameter – 0.92 0.03mm
Diameter - 0.31mm
Color - Clear
16/6/0.050mm±0.003
Coverage – 95%
Diameter – 1.37 0.05mm
Color – Grey GY-08/Black
Diameter – 1.15 0.05mm
SPE-15-8-042/B/WY
Page 3 of 6
2.3 Electrical & Physical Specification
1
2
Item:
Rating Temp Voltage:
30 AWG
105°C 30V UL 1979
3
Insulation Resistance:
3000 MEGA OHM-KM Min.
4
Conductor Resistance:
335 OHM/KM/20°C Max.
5
Dielectric Strength:
AC 1.0 KV/minute
6
Spark test:
7
Insulation
2.5 KV
Unaged
Aged
8
Jacket
Unaged
Aged
Tensile Strength
2500 PSI Min.(1.76Kg/mm²)
Elongation
200% min.
Tensile Strength
Unaged Min 75%(168HRS*232°C)
Elongation
Tensile Strength
Elongation
200% min.
Tensile Strength
Elongation
9
Nom. Impedance
50 3 Ohms
10
Nom. Capacitance
96 3 pF/m
11
Nom. Vel. Of Prop.
69%
12
VSWR (0-6GHz)
Max 1.3
13
Flame Test
VW-1 OK
14
Thermal Shock
Less 1mm at 232C/1 HR
13
Bend Radius
9mm min.
14
Attenuation (dB/1M)
2.0GHz
2.20
2.4GHz
2.60
3.0GHz
2.80
4.0GHz
3.40
5.0GHz
3.80
6.0GHz
4.30
SPE-15-8-042/B/WY
Page 4 of 6
3. Technical Drawing
3.1 CAB.616
SPE-15-8-042/B/WY
Page 5 of 6
3.2 Connectors
3.3Recommended Mounting Hole – SMA(F) Bulkhead
SPE-15-8-042/B/WY
Page 6 of 6
很抱歉,暂时无法提供与“CAB.616”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+55.102001+7.12745
- 10+46.8543310+6.06061
- 25+43.9157725+5.68051
- 50+41.8168350+5.40901
- 100+39.82047100+5.15078
- 300+36.85089300+4.76667
- 500+35.54696500+4.59800
- 1000+33.851771000+4.37873
- 2500+31.734972500+4.10492
