P318-06N-FMM
P318-06N-FMM
    TRIPPLITE
    CABLEADAPTER
P318-06N-FMM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3.5 mm 4-Position to 3.5 mm 3-Position Audio Headset Splitter Adapter Cable (F/2xM), 6 in. (15.2 cm) Highlights ● Connect a 4-position headset to your computer or laptop ● Use your headset on your computer or laptop with Skype, chat, and other VOIP applications ● Molded cables with built-in strain relief MODEL NUMBER: P318-06N-FMM Package Includes ● Connect a 4-position headset with both audio and mic to the 3.5mm audio and mic ports on your computer or laptop Features ● Connect a 4-position headset to your computer or laptop ● Use your headset on your computer or laptop with Skype, chat, and other VOIP applications ● Molded cables with built-in strain relief ● Constructed of 28AWG wire ● Features a compact design perfect for tucking into your laptop bag when you're on the go Specifications OVERVIEW UPC Code 037332184030 Product Type Passive Cable Technology Stereo Audio Cable Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 0.5 Cable Length (m) 0.15 1/2 6-in. 4-Position Female to (x2) 3-Position Male Audio Adapter Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.08 Shipping Weight (kg) 0.04 CONNECTIONS Side A - Connector 1 3.5MM, 4-POSITION (FEMALE) Side B - Connector 1 (2) 3.5MM (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P318-06N-FMM
物料型号:P318-06N-FMM
器件简介:这款3.5毫米4-位至3-位音频耳机分割器适配器线缆(F/2xM),长度为6英寸(15.2厘米),用于连接4位耳机(包括音频和麦克风)至电脑或笔记本电脑的3.5毫米音频和麦克风端口。
引脚分配:侧A-连接器1为3.5毫米4位(母头),侧B-连接器1为2个3.5毫米(公头)。
参数特性: - 产品类型:被动线缆 - 技术:立体声音频 - 线缆类型:被动 - 线缆长度:0.5英尺(15.24厘米) - 颜色:黑色 - 线缆外皮颜色:黑色 - 产品合规性:符合RoHS标准 - 产品保修期:全球范围内有限的终身保修
功能详解:该适配器线缆允许使用4位耳机在电脑或笔记本电脑上进行Skype、聊天和其他VOIP应用程序的通话。
应用信息:适用于需要将4位耳机连接到电脑或笔记本电脑的3.5毫米音频和麦克风端口的场景。
封装信息:线缆长6英寸(15.24厘米),包装尺寸为7.00x9.00x0.50英寸,运输重量为0.08磅(0.04千克)。
P318-06N-FMM 价格&库存
很抱歉,暂时无法提供与“P318-06N-FMM”相匹配的价格&库存,您可以联系我们找货
P318-06N-FMM
  • 1+48.318831+6.27257
  • 10+41.0837810+5.33335
  • 25+38.5107525+4.99932
  • 50+36.6695350+4.76030
  • 100+34.91898100+4.53305
  • 250+32.73292250+4.24927
  • 500+31.17125500+4.04654
  • 1000+29.684611000+3.85355
  • 2500+27.828242500+3.61256
库存:28
