LF4GYX
LF4GYX
    SWITCHCRAFT
    PATCHCORD 1/4" GRAY 4FT
LF4GYX 数据手册
NPB 559 1/4" Longframe Patchcords PRELIMINARY 1/4" Longframe Single Patchcords Introducing Switchcraft's re-designed 3-conductor 1/4" Longframe audio patchcords. Now made with a low capacitance 110 Ohm cable it is ideal not only for analog applications but also for digital AES/EBU audio and SMPTE time code patching. The overall flexible jacket is available in eight attractive colors. The overmolded rubber flex handle-boot reduces strain off the cable when pulled or tugged. The overmold covers a metallic shell which greatly reduces crosstalk. The nickel plated plugs ends are non-tarnishing as well as self cleaning when used with Switchcraft MT series patchbays. w w w . s w i t c h c r a f t . c o m 5555 North Elston Avenue / Chicago, IL. 60630 Phone: 773-792-2700 Fax: 773-792-2129 Made in the U.S.A. 2 NPB 559 High Performance Audio Patchcords Broadcast Series 1/4" Longframe Analog and Digital Audio Patchcords Part Numbering System LF Longframe Colors Black Red Orange Yellow Green Blue Purple Gray = = = = = = = = Length (Feet) Cable Color Color Code Standard Foot Lengths BK R O Y GN BL P GY 1' 2' 3' 4' 5' 6' 7' 8' 9' 10' Custom lengths are available by request. 1 meter is equal to 3.28 feet. SPECIFICATIONS: * Mil Spec Series: M642 * Standard plug terminations are 1/4" Longframe Plug handle is molded thermoplastic. * Plugs: Tip Rod, Ring and Sleeve - Copper Alloy * Cable: 26 AWG (30x40) OFBC, 110 Ohm Low Capacitance Jacket is Matte PVC w w w . s w i t c h c r a f t . c o m 5555 North Elston Avenue / Chicago, IL. 60630 Phone: 773-792-2700 Fax: 773-792-2129
LF4GYX 价格&库存
很抱歉,暂时无法提供与“LF4GYX”相匹配的价格&库存,您可以联系我们找货
